steering wheel problem???
Old Aug 7, 2003 | 06:33 PM
AFIwrx's Avatar
Unhappy steering wheel problem???
Ok since i got my ebach springs and new tires i have been getting some weird steering. When i turn right and let go off my steering wheel it comes back to center but its like 3-4 degrees crooked but when i turn to the left it goes back to center?? has this happened to any one before?? i was thinking there was something wrong with my rack and pinon??
and input would be helpful
thanks
mike
damn steering
Old Aug 7, 2003 | 06:43 PM
dropkick_muppet's Avatar
Car Info: '03 PSM Sedan
did you get an alignment done after installing the new springs? most handling issues related to new springs come down to that.
also, the WRX rack seems to have quite a bit of play in it, as well as a large degree of play in the bushings. mine does this on stock springs, even with aftermarket steering rack bushings (noltecs).
Old Aug 7, 2003 | 06:53 PM
AFIwrx's Avatar
yeah i just got an alignment today and the tech guy also noticed it when he did his road test. so is this normal do i have to worry about it i was thinking of going to the dealer but i would like to avoid that as much as possible because of all my mods and they would charge me up my a$$ if they need to fix anything
thanks for the input
Old Aug 7, 2003 | 08:17 PM
i think that a lot of people here have probably experienced this problem, but you might do a search to be sure if you haven't yet.
someone please correct me if i'm wrong, and we're the only two with this issue (mine only happens somtimes).
did this start right after the spring install, or did you notice it before?
Old Aug 8, 2003 | 10:47 PM
That little bit of steering wheel play is there for high speed stability. You wouldn't want to accidentally add 2 degrees of steering input at 130+ mph reaching for the headlight switch or something. Bad stuff. So, you gotta deal with just a little bit of numbness at low speeds.
Did the tech notice that the wheel was crooked, or that there was a little play?
Old Aug 9, 2003 | 03:13 AM
AFIwrx's Avatar
he noticed that when making a right turn and then letting go of the wheel the steering wheel would stay turned but when making a left turn it would go back to center.
Old Aug 16, 2003 | 12:18 AM
HJC's Avatar
HJC
I had the behavior on my 03 WRX.
Hard left turn, steering on center.
Hard right, steering on tilted to right.
Got alignment done.
Hard left turn, steering is tilted to left.
Hard right turn, steering on center.
Installed whiteline steering bushings. Problem solved. Always centered. Steering is much more responsive too. Stock bushings, the steering response felt like my old 95 Corolla. Now it feels more like a sports car.
Check nasioc.com and search for "memory steer" or "steering bushing". I wish I saw those articles before I wasted my money on the alignment.
Some say even with the upgraded bushings, the problems still exist, but luckily it worked for me. For $25, it's worth a try. Installing was a pain though.
Old Aug 17, 2003 | 04:42 PM
AFIwrx's Avatar
coo thanks
Old Aug 22, 2003 | 11:41 PM
i upgraded the steering rack bushings, but the problem didn't go away until i instaled my STi struts, springs and top hats. i think it was the top hats that made the differance, after the alignment i had done the steering wheel is dead on all the time now.
Hotshower
Apr 11, 2013 09:45 PM
HandyRS
Subaru OEM Parts For Sale
Aug 25, 2006 07:57 PM
sjice
Jul 6, 2006 05:29 PM
SSFWRX
Dec 30, 2005 01:36 AM
I3eXa
Mar 7, 2005 08:01 AM
