Rusty brake rotor hubs?
Old May 31, 2003 | 06:20 PM
Dave99's Avatar
Car Info: '02 WRX sedan
I've heard brake pad dust is pretty corrosive. Would dust deposition on hub surfaces tend to accelerate rusting?
Old Jun 9, 2003 | 08:29 PM
Bump for Dave. Excellent question.
Old Jun 13, 2003 | 05:56 PM
dropkick_muppet's Avatar
Car Info: '03 PSM Sedan
according to the folks at Kelly Blue Book, brake dust is corrosive:
http://www.kbb.com/kb/ki.dll/ke.kb.sp?kbb&&395&care
now, i have honestly never seen brake dust case wheels to pit/corrode/rust/etc and i've been arround my fair share of brake dust. if you plan on keeping your car (and your wheels) for a really long time, it might be something to worry about. one problem that's more common, especially if you have cast iron discs, is to have the rotor develop rust spots. those generally go away when you use the brakes again. having the hubs rust is kinda odd, i've never seen it (and i just pulled the wheels off my WRX this past weekend).
when removing sutff like this don't use soap or water, it'll only lead to more rust. if it's a film of dust on a non-painted surface i.e bare metal, you can use acetone to loosen the crud and wipe it off. careful, your paint doesn't like acetone. steel wool works wonders too, but don't use it on anything painted or clear coated.
Old Jun 28, 2003 | 08:19 AM
Jgrahn555's Avatar
Sarcastic Jackass
Car Info: i drive a beater
I have a friend at work who just recently did this process. He taped off the face of the rotor that makes contact with the pads, and high-temp painted the rest. for the week or so that he's had it done, we haven't noticed any troubles.
SFO GTO
Jul 21, 2011 12:06 AM
dan2304k
Mar 24, 2006 04:40 PM
sireatalot
Mar 17, 2005 06:40 PM
RussB
Sep 8, 2004 11:13 PM
SubySal
Dec 3, 2003 08:22 PM
