Rear brake upgrade for future engine swap
Old Dec 23, 2002 | 01:46 PM
ImprezaRSDriver's Avatar
You should just find the WRX front setup and a RS rear setup and you are good to go. The rear setup should replace the drum setup on the rear. And the WRX setup on the front will be more than adequate.
Old Dec 24, 2002 | 09:56 AM
bamfwrx's Avatar
Car Info: 02 WRX
wrx brakes fitting under 13 rims??
Old Dec 24, 2002 | 11:21 AM
the WRX front brakes will just barely clear 16inch wheels. I know for sure that the Subaru 4pots will clear 15inch wheels. But I doubt that there are any brake kits out there that will clear 13s. I am not familiar with any. I believe that the smallest wheels that rally teams use are 15s.
My bad for missing the info about 13inch wheels.
Old Dec 28, 2002 | 12:23 AM
go go go's Avatar
Car Info: GF8 ver6
Re: Rear brake upgrade for future engine swap
Originally posted by Mr. WU
I currently drive an Impreza 1.8l '93, FWD.
You might be stuck with your stock rear brakes.
FWD knuckles are different from AWD knuckles, it is possible you can't upgrade the rear. You are on drum brakes, right? I might be wrong so you need to look into that before you buy anything.
WRX brakes won't fit 13 for sure.
I have 94 FWD and converted to WRX front brakes, the stock 14 doesn't fit anymore.
I upgraded rear brakes to legacy disk brakes but I did the AWD conversion at the same time.
BTW rear suspension is not interchangeable between FWD and AWD because of that damn FWD knuckles.
PacificLegacy
Aug 26, 2014 09:54 PM
w1ngzer0
May 6, 2006 09:05 AM
SubySal
Dec 3, 2003 08:22 PM
Ni3Frontier
Apr 17, 2003 09:44 PM
