Problem with my STI brembo brakes
Old May 2, 2004 | 04:00 PM
SlickmisterN's Avatar
Car Info: 2004 Black/Gold STi
The sqeeking in reverse is normal. And if I roll down my windows and put on the brakes i can hear the friction and it sounds like rubbing? Is that what your hearing? If not it might be a rock or your low on fluid?
Old May 2, 2004 | 04:08 PM
wrexr's Avatar
Car Info: E28M5, RAM Powerwagon, Motos
The sounds you are hearing are common of the STI Brembos. They are a agressive pad compared to most street pads, hence the high brake dust. The reverse squeaking is also common, just one of those things with high performance brakes. Low brake fluid would not make the friction sound you are hearing. If the grinding sound has gotten worse, check with your dealer.
good luck
Kevin
Old May 6, 2004 | 03:11 AM
silver satin's Avatar
Dump the stock pads...I picked up some Project Mu. No squeaking, almost no dust and better pedal feel and subject has been discussed many times it is normal just do a search next you should be able to find mucho info...Friend has the Feredo's and likes them very much...
jung187
Feb 15, 2011 12:00 PM
AMS
Jul 27, 2007 09:10 AM
zion168
Jul 8, 2007 02:34 PM
nathanellis
Dec 23, 2004 11:41 PM
suby_dude
Vendor Group Buys/Specials
Aug 23, 2004 12:59 PM
