Power Slot rear rotors for WRX sedan
Old Nov 19, 2003 | 09:13 AM
Dave99's Avatar
Car Info: '02 WRX sedan
Hi,
I need to replace my rear rotors in my WRX sedan. I found some cheap vented and slotted rotors from an aftermarket company named "Power Slot". Here's a link to a vendor.
http://www.hopupracing.com/poslreslroki1.html
Has anybody used these rotors before? Do they make them with durable cast iron? Are their flatness and concentricity machining tolerances decent? Do they brake well? Will they crack? Do they weigh a lot relative to the Subaru OEM solid rotors?
The price seems really low so I'm a little curious about their quality. I'm not interested in a mega-bucks Brembo or Pro-Drive rear rotor package because the rear rotors don't take all that much load compared to the fronts. Any experiences with "Power Slot" products would be very much appreciated.
Regards,
Dave.
Old Nov 27, 2003 | 07:41 PM
AntsWRX's Avatar
Car Info: 2004 WRX
I also used Powerslots on my last car, an Integra GSR. Replaced them with Hawk pads. Made a big difference in braking response and feel. I would consider using them when I have to replace the rotors, but I am also interested in the Baer rotors on the Tirerack website. I just wish that Hawk would make pads for the '04 WRX. As far as I know they have not done this yet. If anyone knows any different let me know.
Old Nov 27, 2003 | 11:46 PM
Uncle Scotty's Avatar
My DBA's have done very well....
Old Nov 28, 2003 | 07:49 PM
Dave99's Avatar
Thanks for all the feedback fellas.
I took the big plunge last week (more like a little splash as far as car upgrades go) and bought the rear WRX PowerSlot rotors from www.subarustore.com . They are affiliated with Titan Motorsports I think. I dealt with Bottle (?!?). Anyway, they were in stock and they arrived promptly a few business days later. Good price and good service.
The weight is very similar to OEM. I thought the rears were vented but they're only slotted. They are apparently machined from the same blanks as the OEM rotors so that would explain the similar weight and why they're not vented.
The machining looks good. The surface is very even and you can see they lathed all external visible features for good cosmetics and rotational balance. All mounting surfaces are machined flat, of course. Even the external corners are chamfered, which is a nice touch. They plated the rotors with cadmium for rust resistance. Nasty heavy metal but I suppose they choose this for a reason (corrosive brake dust resistance?).
They went on just like stock and they seem fine. I've bedded them in but it's rainy tonight and I'm supposed to refrain from extreme braking for the next 300 - 500 miles so I can't really comment on their performance. They felt good during bed-in.
I replaced these rotors because I have a vibration somewhere in my rear drivetrain. The mystery vibration hasn't completed abated now that I've replaced the rotors but it's fundamental mode has shifted up to 55 - 60 MPH and seems to cover less range. I think the old rotors were creating another similar mode at 40 MPH. These replacement rotors appear to have improved the situation. Next step . . . the axle. Let my foolish powersliding on snowy roads be a lesson to every rally driver wannabe. Curbs hurt.
So all in all, the rotors appear to be just as good as OEM with the additional cadmium plating and slotted surfaces to boot. At 2/3 the price of OEM, it's hard to let friends get suckered into buying OEM. The PowerSlots for now appear to be a cheaper and hopefully superior alternative to OEM. I'll follow up once I've had a chance to push them a little but it's pretty hard to say with rear rotors because they do such little work in comparison to the fronts.
Dave.
BrendanTheGreat
Mar 21, 2013 07:59 AM
wrxlover
Jun 28, 2004 11:56 PM
wonton2049
Apr 30, 2004 07:26 PM
bemani
Oct 30, 2003 09:59 AM
bemani
Oct 15, 2003 05:51 PM
