Noise on suspension???
Car Info: Old Brighton
I have coilovers then I just put front and rear strut bars now once in a while when i turn I hear like a pinging noise (sounds like the springs are flexing
)Is that normal or something's wrong with it..When i changed my tires i noticed that the springs were moving(you could turn the spring around) Is that normal too cuz the car is low or something's wrong again..
Car Info: 2004 STi Yellow/Black
Well, Coilovers are noisy. Mine make all sorts of noise but I have also managed to replace a lot of other suspension components. So while I am not sure about the specific noise you are describing. Noisy is normal.
When you have the coilover unloaded you should be able to turn the spring. Coilovers work differently than a normal strut/spring combo.
http://www.stifiles.com
stott
stott
Originally posted by Borjaq
Some coilover kits come with bearings that you install to keet the spring from rubbing the top of the sprin holder. I had the same problem when I first installed mine. The bearing looks like a washer with tiny wheels in it. Hope that helps.
JUNNEL20
13
Jul 1, 2003 04:02 AM
cobraKLR
Jun 17, 2003 01:31 PM
STiNightFall
Dec 14, 2002 01:12 PM
