Noise after intalled poltek FR endlinks
Old Sep 21, 2004 | 03:08 PM
orwrx's Avatar
Car Info: WRC replica
I just installed a set of this last Sat and noticed there was a chunking/clicking noise coming from the front. I got this set without instructions. I'm not sure if I installed it wrong. I had STI alum. front control arm and Cusco 21mm swaybar with this endlinks. Sounds like the links was hitting something underneath, but I couldn't figure it out. Please help guys. Pics will be helpful.
Andy
Old Sep 21, 2004 | 06:35 PM
Egan's Avatar
What car and what endlinks (Poltec makes STi and WRX specific endlinks)?
Old Sep 22, 2004 | 12:30 PM
orwrx's Avatar
Poltec makes STI and WRX endlinks for FR and RR.
Old Sep 22, 2004 | 01:42 PM
Egan's Avatar
What I was asking, in an attempt to help you, is which ones did you buy and which car do you own.
Old Sep 22, 2004 | 01:45 PM
orwrx's Avatar
O sorry, I got confused man. I got 02WRX and WRX type of links.
Old Sep 22, 2004 | 01:58 PM
Egan's Avatar
Here are a couple of pics from my installs.
This one is Whiteline links with the stock WRX front bar:
This one is off my STi and shows the Cusco bar with stock links:
Check your Poltec links and make sure they are the same length as the stockers (since they are adjustable). If that's okay, check your bar orientation relative to the pics above. Make sure you installed the bar the correct way (it's common to install it backwards/upside down).
Old Sep 24, 2004 | 04:14 PM
pcowan's Avatar
Car Info: '04 STi - RallyX beast
make sure the nuts for the endlinks are tight... most of the time I've had or heard of this sort of thing it because of bolts that seem tight that aren't tight enough.
i<3dirt
Oct 20, 2014 10:26 AM
72DATS510
Cars For Sale
Oct 9, 2010 03:31 PM
72DATS510
Jun 11, 2010 03:39 PM
adamsrs
Jul 22, 2004 06:18 PM
JDClubSi
22
Jul 9, 2004 10:20 PM
