need some quick-answer brake pad questions
Old Nov 13, 2003 | 12:05 PM
hays00s's Avatar
Car Info: 2002 WRX Wagon
still learning noob here, '02 WRX stock wgn ~25k miles
i'm squealing/chirpping and positive that i need to replace the worn down brake pads. not a lot of cash in the pocket, so i only want to fix what's necessary (upgrades will come later)
1. will the Axxis Ultimate pads (front and back) fit on the OEM brakes? any other suggestions, better ideas?
2. is there an FAQ on how to do this?
3. when puchasing from, the pad set is for each wheel? (looks like two pads to each wheel)
4. how long does the install take (now that the afternoon light fades fast)
tnx-
seus
Old Nov 13, 2003 | 04:27 PM
hays00s's Avatar
hunting around i found this thread:
http://www.weblumen.com/subaru/brakepads.html
great job of capturing pad replacement.
now i just need some info on best pads for the cash that fit on the stock brakes... anyone got info/suggestions?
i read that Axxis create a lot of dust and the Carbotech's are less dusty?
Old Nov 13, 2003 | 04:29 PM
Peaty's Avatar
Search for brakes on our Scoobymods.com site there is info there on changing them out.
Old Nov 16, 2003 | 12:37 AM
Uncle Scotty's Avatar
Best to inspect your brakes, and verify what you need first of all.
You may not need brake pads at all. I drive my car hard and the pads were fine(worn about 2/3) at ~25k miles and were starting to squeak/squeal a bit.
Brake pads are usually sold per axle, meaning you buy a 'set' for the front and/or a 'set' for the rear. A 'set' will be 4 pads.
The Axxis Ultimates are great street pads, and yes they dust. Good performance sometimes comes at a price, and for the price the Ultimates are hard to beat. You could replace all four corners with Ultimates for the price of one axle of some other pads and have enough $$$ left over to buy lots of pizza and beer for the crew.
Old Nov 16, 2003 | 02:30 PM
hays00s's Avatar
thanks Scotty, just the info i was looking for!
brucelee
Oct 16, 2008 12:30 AM
jimr
Jan 14, 2004 09:44 AM
O 16581 72452 5
Sep 18, 2003 09:37 PM
matt6669
Jun 22, 2003 09:26 PM
matt6669
Apr 29, 2003 05:14 PM
