need help:wheel bearing
Old Feb 18, 2005 | 09:40 AM
scoobsport98's Avatar
Car Info: 98 Impreza Outback Sport
Out of everything I've put on my car, this is the ONE thing I had a mechanic install. What model/year subaru do you have? The older imprezas have a notorious problem with the rear wheel bearings- and if one goes out-you need to make sure you get the new recommended sealed-style bearing... not just the replacement part #- My mecahnic actually had recieved a service bulletin from SOA which detailed the new procedure for replacement, which my local delaership didn't even know about yet. I had the impression you needed a press or something to do it- maybe not- can someone else chime in ?
A quick google search, and I found it:
http://www.endwrench.com/current/Cur...s/03-50-02.pdf
it applies to impreza, legacy, and forester.
so, if you have the old-style caged bearing, It looks like you will need a press to get it out.
Old Feb 21, 2005 | 04:13 PM
http://www.subaruwrxparts.com/wrx-interior.html
Scroll to the bottom. The manual you need is about $50, will tell you everything you need to know.
Old Feb 23, 2005 | 12:14 AM
jasonsong2004's Avatar
Car Info: 99 2.5RS Coupe Rally Blue
hey thanks guys for the info. i know im gonna need a press to get it out but id rather remove everything and have them press it out for some money. theyre charging me 350 a side. HELL no i said. rather save the money on other stuff worth fixing.
Old Feb 23, 2005 | 09:57 AM
Is this not worth fixing? When my wheel bearing was blown, it sounded like my car was falling apart, I dunno bout you. I know that sounds steep, but how would you go about getting the car to them to press the bearings out? Wouldn't you have to pay to tow it? So, are both sides done for? what model/year car do you have? I've got the step-by-step instructions- with all of the appropriate new model #'s (many are model-specific)
I pulled out my paperwork file, and my mechanic charged me $153.60 in labor to install the 112.70 in parts, which I picked up from the dealership. It looks like the quote you got was with parts... ask how much it would be if you supplied the parts.
H_wells3000
Jul 21, 2014 10:04 AM
EJ25RS
Apr 4, 2004 11:04 PM
bringndefinitio
Dec 14, 2003 11:02 PM
jennig
Apr 19, 2003 11:43 AM
