Need Help With Springs
Old Aug 27, 2003 | 11:22 AM
Kay95's Avatar
if your worried about the lock nuts being used then just put red loctite on the threads and you should have no problems
450 at http://home.att.net/~teaguesauto/suspension.htm
if you have a first gen impreza
and yes if you do the springs do the shocks too because you have to take them off anyway and why do a dangerous job of changing spring twice and if you dont have the cash for them just wait til you can because you will save alot a cussing and swearing, beating and pounding doing this just once
hope this info helps you
Old Aug 27, 2003 | 07:09 PM
www.gruppe-s.com sells AGX for well under $400 shipped.
jacobp7201
Jan 26, 2011 11:18 PM
unstble
Mar 21, 2008 09:09 AM
perolo
Feb 14, 2005 05:38 PM
JDM_STI
Dec 25, 2003 10:24 PM
youie
Mar 2, 2003 06:34 PM
