Mitsu EVO brembo brakes on WRX?
re brembo brakes
Razor, I assume you are talking about the brembo pads? We have found the brakes will fit on the sti but w/out the shims.
-john
www.brakeworld.com
-john
www.brakeworld.com
No, the actual Brembo front calipers from the Mitsu EVO 8. Do they bolt up just like the STi Brembos?
I know the pads are different, but can I use STi pads and rotors with the EVO 8 Brembo's and can the calipers bolt up to a 04 WRX sedan?
:bryan
:bryan
Car Info: 96 Chevy Impala SS, 06 GMC 2500HD (former 02 WRX)
I'd be really surprised if the answer is "yes".......each OEM tends to do unique mounting points and the like when they use Brembo calipers.
Former Sponsor
Car Info: Evo X, 04 STI, 335i, Fit
razorlab- I already looked into that and the answer is NO. The caliper design is the same, but the mounting points on the hub is different. Since the mounting bracket is integrated w/ the caliper, the mounting points cannot be changed unlike a Stoptech BBK where the mounting bracket is separate from the caliper assembly.
-Soren
-Soren
-Soren
-Soren
Originally Posted by senortighto
the diameter of the brake discs on the STi are a few tenths of an inch larger than the evo's, like 12.9 in for the STi and 12.5 for the evo.
just a little fun fact
The STi fronts are 322mm (12.7")
jung187
Feb 15, 2011 12:00 PM
AMS
Jul 27, 2007 09:10 AM
