Improving handling and fixing squeeky brakes
Old Oct 2, 2004 | 10:49 AM
C_Noles's Avatar
Car Info: 01 Legacy GT
Question Improving handling and fixing squeeky brakes
hey i have a 95 Legacy L 2.2 awd auto. I'm all stock and would like to improve the handling on it but I'm not sure where to start and could use some suggestions on what would give me the best handling for a cheap price and if theres anywhere specific i should look for them. Canadian dollars would be appreciated.
and just another thing, i have had squeeking coming from my brakes, mostly from the front i believe, and my mechanic machined the rotors a few times and still sounds like a bus stopping.
First off they said it was probably just rust and to drive it for a week or 2 and it should go away, it didnt, then they said whoever worked on my car b4 had the rotors on slanted or something, so he machined them but still squeeks, then i got my cv boots replaced and more machining and i think the noise got worse.
Like sometimes i hear something squeeking each rotation the tire makes, usually when driving slow. And sometimes when coming to a stop or when driving slowly and turning i hear a sort vibration somewhat the same as when ABS kicks in but nothing like that on my brake pedal. Maybe a joint? Is there anything i should know or ask when going to the mechanic this time around so I that im not getting screwed over??
If youve read this far thanks very much and hope to hear from you
and if youve answered previous postings thanks again
C_Noles
Old Oct 24, 2004 | 12:00 PM
C_Noles's Avatar
Question
thanks for writing back, I replaced the brake pads, but theres this noise that comes and goes but when i hear its with every rotation the tire makes, and when i had my car looked at they said the front right axle seal is leaking and the front right is where the noise seems to be coming from, could this be causing the noise, like maybe when its a bit dry the noise comes?
thanks for your help
C_Noles
Old Nov 14, 2004 | 01:52 PM
sha_zapple's Avatar
A great cheap upgrade for handling is a rear swaybar. It really makes a difference. I got a used one off of an outback, and that made a huge difference. Buying an adjustable aftermarket one would help even more.
Old Oct 19, 2005 | 08:09 AM
kirk's Avatar
Car Info: 96 Subaru Legacy L
i had the same problems on my 96 L...replaced cv boots, pads, and rotors...the squeaking went away...but now i have a really loud squeal everytime i make a right turn...dont know what it could be...and also everytime i hit a bump i feel a bunch of thuds coming from the front suspension...just replaced front axle as well so im clueless...any tips?
AMS
Jul 27, 2007 09:10 AM
C_Noles
Sep 30, 2004 03:29 PM
suby_dude
Vendor Group Buys/Specials
Aug 23, 2004 12:59 PM
BajaNut
May 15, 2003 01:36 PM
