I think somethings seriously wrong with my rear suspension
Old Apr 30, 2004 | 11:54 AM
DaWorstPlaya's Avatar
Car Info: WRB 2003 WRX
What type of endlinks did you get? because I have read that the ones with spherical? joints allows the swaybar to walk which is not a good thing. Correct me if I am wrong fellas .... On the other hand your bolts might not be torqued down properly as in the thread below:
https://www.i-club.com/forums/showth...threadid=54886
Goodluck
Old Apr 30, 2004 | 12:25 PM
redrex's Avatar
Car Info: was 05 WRX Wagon
Did you put some type of grease or teflon tape in between the bushings and the bar? The polyurethane bushings give this clunking/ creeking sounds when load is applied to them (since you only hear the sound when making turns or going up driveways at an angle I assume). You're going to have to take the bar off the mounts, wrap some teflon tape around the area of the bar that the teflon bushings sits on, then re-intall them again. Make sure the bar is centered properly also. Good luck and hope this helps.
-Soren
Old May 6, 2004 | 11:27 PM
mrruins's Avatar
Car Info: 05 toyota tacoma
There is a tube of grease that is suppose to go with the Perrin endlinks? Can I use WD-40 instead?
Irrational X
Dec 5, 2010 06:57 PM
06scooby
Sep 23, 2007 12:39 PM
supra_man
Aug 11, 2006 03:40 AM
Emsraumajunke
Apr 28, 2005 11:44 PM
monkey777
Dec 9, 2004 02:18 AM
