Help with spring rates
Old Dec 29, 2003 | 12:14 AM
verc's Avatar
Car Info: GT35R, Meth
Hey all,
someone asked me a question about my springs and I can't really answer it since I'm not that knowledgable with suspension:
"Hey Ambert,
Can you do one thing for me? Can you translate the spring rate
to lbs/in pls? I'm coming up with something like 168lbs/in which makes
them a lil too soft for me, just a few lbs over stock. I hope I'm doing
it wrong. How stiff were they for youbtw? Thanks.
Dinh"
These are Tanabe Sustec GF210 (babysmurf you can correct me if I'm wrong)
Thanks!
Ambert
Old Dec 29, 2003 | 04:54 PM
verc's Avatar
someone's gotta be able to answer this question
Old Dec 29, 2003 | 04:56 PM
Daredevil's Avatar
im stooped
btw can someone explain to me what rates for coil overs mean?
as in 5kg front and 7kg (or is it just k) or what? i can't remember right now, hopefully somone knows what im talkin about
Old Dec 29, 2003 | 05:04 PM
highspeed11's Avatar
Car Info: '05 LGT
I'm not sure exactly what the question is but here's this site with the stock spring rates among others.
http://www.ravensblade-impreza.com/t...ng/spring.html
The Tanabe Sustec GF210 are supposed to be 20-30% higher than stock according to this.
http://www.hpautoworks.com/tasugflosp.html
Old Dec 29, 2003 | 05:40 PM
Jay784's Avatar
Car Info: 02 WRX
Originally posted by Daredevil
im stooped
http://www.anzwers.org/trade/hsdraci...onversion.html
Old Jul 26, 2004 | 12:08 PM
thetraut's Avatar
does anyone know the spring rate for perrins, i noticed they weren't on the chart
Old Jul 26, 2004 | 04:22 PM
platypus's Avatar
Car Info: dangerous with a wrench
If they are the same perrin springs as I've seen in the past, they are a progressive rate spring, but I haven't measured them to know what the rate curve is like.
Old Jul 29, 2004 | 08:03 PM
blue5spdwrxwgn's Avatar
Spring are rated in units of force per unit of displacement.
The metric unit of force is the Newton, so spring rates are rated in Newtons per millimeter (N/mm). The gram is a unit of mass. In english units it is pound force per inch (lbf/in).
Old Oct 17, 2004 | 08:56 AM
ac_attack's Avatar
Correction 1 inch is .04 mm so to convert Kg/mm to lb/in you multiply by 2.2lbs then devide by .04. or the quick way is to multiply by 55.5. Those 8Kg springs would actually be 8x55.5=444lb/in.
Another is converting N/mm to lb/in. 1N is .225lb so you multiply by .225 then devide by .04 again the quick way is just to multiply by 5.625.
BTW Some places that use the metric system also rate horsepower in PS. -PSx.986=HP it's still based on how much weight a donkey can haul up a mine shaft though, i think.
WIN IN
Oct 20, 2012 04:34 PM
8200rpm
Aug 24, 2010 07:49 PM
Evegan
Dec 23, 2003 08:56 PM
Juliano
Sep 24, 2003 07:38 AM
JustinWRC
May 12, 2003 12:41 AM
