Help should I...
Old Jan 23, 2003 | 04:25 PM
The Works's Avatar
Car Info: Joe P MBC, Walbro 255 fuel Pump, Cold Air Intake,Apexi Turbo Timer, HKS Downpipe, Apexi Cat Back,BOV
Help should I...
Hi i got my 18 rota subzeros and i jsut got my sprint springs. Should i put them on. what are the effects of just doing springs on the suspension like tire wear do i need the camber bolts what do i do. thanks
Noah
Old Jan 23, 2003 | 10:37 PM
Steppin Razor's Avatar
@Stoptech
Car Info: 2002 WRX Wagon
Put the springs and the wheels on and then go to a performance alignment shop and get an alignment done. You won't believe the difference.
Old Jan 24, 2003 | 04:47 PM
ImprezaRSDriver's Avatar
Well what springs do you have first of all?
Because different springs will drop the car to various heights. But once you put the springs on, definitely have the car aligned. You will not need camber bolts unless you plan on changing the rear camber. The alignment shop should be able to adjust the front camber to your liking. You will feel a difference. Also more camber will also mean that your tires will wear a lot quicker on the inside than on the outside.
Old Jan 24, 2003 | 05:21 PM
The Works's Avatar
i have sprint spring well im at work and the mechanic has been giving me the f-ing run around im so pissed so finally he goes to do it today and he is like i dont like how the springs are lining up with the struts. im like fine put the **** back on im so pissed just f-ing do the job. i talked to 02blackwrx and he said he had no probs with his stuff.
Ridoan
Sep 8, 2009 11:40 PM
Mushman
23
Jan 28, 2005 11:19 AM
dr3d1zzl3
Aug 20, 2004 03:19 PM
hokusai
Jun 28, 2003 11:38 AM
The Works
Jan 1, 2003 06:18 PM
