HELP!! rotor grinding on caliper bracket
Old Mar 13, 2009 | 01:24 AM
hesh_one's Avatar
Car Info: 02 WRX/04FXT/07 STi
I have a 2002 WRX at 80k miles. stock brakes, rotors, suspension..
i was driving when i noticed a bad metal scraping/grinding/clicking in the front passenger side wheel. so i checked and noticed my wheel bearing was completely gone. i also noticed my rotor had been rubbing up against the caliper bracket and dust plate.. just figured it was from all the play in the hub.
so after replacing a bad wheel bearing and axle on the front passenger side and putting everything back together, i experienced the same grinding sound. so i pulled the wheel back off and inspected the brake assemblly. it seems there was still play in the rotor. thought maybe the brake caliper was seizing so i disconnected the caliper and shot air through it to see if it moved. seemed a little iffy so i decided to replace it. after completely replacing the caliper and bracket it STILL was grinding on the bracket.
it seems as if the caliper isnt clamping to allign the rotor.
so its my guess that it could be a warpped rotor? or maybe the axle isnt tightend enough? i dunno..
*Dont know if its related to this but my ABS is all messed up as well
PLEASEEEE help me figure this out.
here is another similar case except im brakes are all stock:
http://forums.nasioc.com/forums/show...rotor+grinding
Old Mar 13, 2009 | 01:54 AM
evotallier's Avatar
Car Info: '02 MBP WRX
Funny, I am having the exact same problem right now. If anyone could answer this, that would make two that would appreciate it.
Old Mar 13, 2009 | 06:35 AM
Wingless Wonder's Avatar
Your link doesn't work because you copied and pasted the text instead of the .url itself.
Old Mar 14, 2009 | 02:02 AM
hesh_one's Avatar
fixed link
Old Mar 14, 2009 | 07:20 PM
tofuman's Avatar
Car Info: a blue car
Have you tried replacing the caliper mounting bracket? Might be bent?
Old Mar 15, 2009 | 05:34 AM
hesh_one's Avatar
yes. brand new caliper and caliper bracket.
Old Mar 20, 2009 | 09:03 PM
tofuman's Avatar
Any luck? Curious as to what the culprit was.
Old Mar 23, 2009 | 06:38 PM
DemonPossessed's Avatar
Car Info: 05 wrx
it could be the bolts that bolt the bracket to the knuckle. are you using the right ones? just a thought
kaiba
Dec 31, 2013 09:36 AM
charlottecayaby
Jul 30, 2012 06:10 PM
dougyfresh18
Aug 6, 2004 08:50 PM
SubySal
Dec 3, 2003 08:22 PM
Phaedrus
Wanted
Dec 1, 2003 11:07 AM
