Help reinstalling stock suspension!!
Old May 18, 2004 | 06:29 PM
lildragn11's Avatar
Car Info: '05 Saabaru 92x Aero
I'm currently trying to reinstall the stock suspension back on the car which has been lowered on coilovers for the past 30,000 miles. I was wondering if anyone could give me tips on how to do this for '01 2.5rs.
I tried to reinstall the rear left strut yesterday and found that i could not lower the whole brake hub assembly to match up the holes on the struts. Do i need to loosen the bolts on the trailing arms or something?? I know it's prolly something stupid and easy!!! ANY HELP, I NEED IT!!
Old May 19, 2004 | 10:04 AM
DaFastOne's Avatar
Car Info: 08 evo x
i recent put my stock suspension on. what u have to do is move the brake hub towards u so u can get the bottom bolt on then u have to push teh brake back up so its perpendicular to the ground, this will take some strength. i hope this helps
Old May 19, 2004 | 10:17 AM
ish's Avatar
ish
how did you have the car lifted? was the entire back end off the ground? if the other rear wheel was still on the ground the sway bar will not allow the hub to move down as you please
Old May 29, 2004 | 10:23 PM
nosnam's Avatar
Car Info: 2003 subaru
you have to jack up the other side of the car and that will let the side you are workign on to drop enough.
Old Jun 4, 2004 | 11:18 PM
BongMan's Avatar
Car Info: '01 RS BRP
for the stock suspension reinstall it would be best to take both sides off. if one side is too tight then it will be hard to put the longer oem setup back in.
However, reinstalling the stock units is never fun because of this.
larry
steen80
Feb 6, 2014 12:38 PM
saltysti
Jul 11, 2009 09:04 PM
YooShin
Jul 11, 2006 01:27 PM
1FSTREX
Feb 17, 2006 04:39 PM
ElJefe
Mar 5, 2005 11:39 AM
