help with projectors
Old Mar 22, 2007 | 07:39 PM
gtfaded's Avatar
Car Info: 2002 wrx
my projector lights keep the car thinkin the highbeams are on, anyone know of quick fix for this
Old Mar 23, 2007 | 02:42 AM
taerron's Avatar
what kind of projectors are you using? did you have to do any custom wiring? might help if we knew this so that we can help you.
Old Mar 23, 2007 | 10:38 AM
gtfaded's Avatar
Car Info: 2002 wrx
ok, no customizing, and the wothless ebay ones
Old Mar 23, 2007 | 06:47 PM
Mulder's Avatar
Car Info: 02 WRX WRB
Yes they are worthless.
They are also wired wrong which explains your problem. You need to swap the pin with the two black wires (assuming they still are like this) so it is in the center of the connector. If you got it right the projectors should be the low beams, the reflectors the highs, and the high beam indicator should work properly. The light output will still be crappy.
Old Mar 24, 2007 | 05:48 AM
gtfaded's Avatar
Car Info: 2002 wrx
Thumbs up
hell yea thanx.
oazntoyo
Nov 16, 2011 05:12 PM
bluewrxagon
Feb 24, 2003 11:55 AM
MashiMOMO
Feb 5, 2003 11:45 AM
gooter80
Dec 14, 2002 09:13 AM
Precentor
Vendor Group Buys/Specials
Nov 27, 2002 02:21 PM
