help on my98 impreza l to rs front brake conversion
Old Oct 25, 2003 | 05:15 PM
You need the Calipers, pads, and rotors. Since you're doing that, I would pick up a set of Goodridge stainless stell brake lines at the same time. Also, if your car has rear drum brakes, I would swap those out with RS brakes too.
Are you getting an extra good deal on the RS brakes? Because the WRX brakes are only a little more expensive and still fit under 16" wheels.
Old Nov 4, 2003 | 07:46 AM
ImprezaRSDriver's Avatar
I believe that the front brakes on the 98 Impreza L are the same as on the 98 Impreza RS. I know that Subaru did not change the calipers for many years and in 98 they all ran the same size at the front. I believe that the pads of the 02WRX(and only 02 calipers) will work with the smaller RS brake setup.
Vivalapat243
Jul 17, 2012 10:41 AM
RS25Tuner
May 10, 2004 05:52 PM
kindil
Apr 29, 2004 02:14 PM
ronny turbo
Feb 3, 2003 12:07 PM
jjunior887
Wanted
Dec 8, 2002 10:02 PM
