Help Damper Setting on BC Coilover
Old Oct 22, 2007 | 08:29 PM
Gilbert927's Avatar
Car Info: 05 WRB WRX
Help on BC Coilover
Just install BC Coilover on my car. i was wonder what a good setting on the dampers, it for daily driving car.
i tried setting it more in the front then the rear, then more in the rear and less in the front. it feel the same. when im driving on flat road on uneven surface, i feel bouncy mostly slow speed and can feel little bit in average speed.
but it okay goin over blumps.
Old Oct 23, 2007 | 12:39 AM
GripItUp's Avatar
Car Info: 2007 WRX Tr
If you just installed them, then you want to break them in by setting it to the weakest setting, plus don't forget to get an alignment. On an average, you can go about 2 clicks up everyday you drive, to the point where it gets stiffer and stiffer. I've had a lot of coilover experience with my s13 hatchback when I was all crazy about drifting. Congrats on the coilovers.
Old Oct 23, 2007 | 08:17 AM
Gilbert927's Avatar
i think the setting right now is 10 frt and 7 or 8 rear. so i guess i start from here or start from zero or 1 right. how far do i get to stiffer turn to what #'s.
i planning to get an alignment this week, plus im waiting for my camber bolts to come. i need to put on my front sway bar kits and my strut bars on.
Old Oct 23, 2007 | 09:58 AM
charlesj's Avatar
Staff Member
Car Info: 06 STI
On the track, I was happiest with 12/12. For the street, it does not matter as much. Although these are decent coilover, the dampening adjustment does not seem to be very sensitive meaning little adjustments are really not noticeable. I do like to run same front and rear though as this helps the rear to rotate a little better
Old Oct 23, 2007 | 09:36 PM
Gilbert927's Avatar
i just found out that i adj the height wrong. my brother told me from so on nasioc. what if u just adj with the first two ring and not the third. did i mess up spring preload and how to fix or set it back.
if anyone know the measure between the 2 to 3 ring. hopefully fix it. please get back to me soon cause im getting an alignment soon.
Old Oct 24, 2007 | 07:06 AM
charlesj's Avatar
Staff Member
Car Info: 06 STI
For the preload, it should just be snug so that the spring does not move around. Do not compress the spring at all. Your measurement from the top rings to the bottom ring will be different than others depending on the ride height you want. It is a trial and error type of thing. Once oyu get it close, a great idea is to have it corner weighted to get it perfect.
Old Oct 24, 2007 | 07:27 AM
Gilbert927's Avatar
Does any know the preload spec for my coilover, i believe i did adj the preload.
Old Nov 6, 2007 | 12:47 PM
charlesj's Avatar
Staff Member
Car Info: 06 STI
do not preload. They are valved for no preload meaning the srping should be snug so it does not move up or down, but not compressed
Old Nov 6, 2007 | 05:00 PM
NorCalBugEye's Avatar
Car Info: 413whp/461wtq
is there any downside to leaving the dampening on a medium setting when your breaking them in? kinda forgot to go to the lowest setting
Old Nov 6, 2007 | 05:10 PM
charlesj's Avatar
Staff Member
Car Info: 06 STI
Should be fine/ Most coilovers direct you to go with an initial setting somewhere around half anyways
Old Nov 6, 2007 | 07:17 PM
cool, thanks Charles
HectorWRX
Feb 28, 2005 12:20 PM
My_Red_Suby
Oct 9, 2004 01:03 AM
gsgleason
Apr 25, 2004 12:23 AM
wagonrasa
Oct 1, 2003 08:36 PM
ShokWaveRider
Feb 20, 2003 01:52 PM
