going to track next weekend have ?'s
Old Jan 11, 2005 | 11:35 AM
BioMech17's Avatar
have 02 wrx, the only suspention upgrade's are Tein S tech and 18 wheels. Im on a budget and would like to know does a RSB really make that much of a difference.
Old Jan 13, 2005 | 07:21 AM
Egan's Avatar
A larger rear swaybar will reduce the inherent understeer. For the WRX, I would recommend an adjustable bar like Whiteline or Cusco. You can start on the lower setting, spend some time in the car, and adjust accordingly. Adjustable bars are usually in the 20-22-24 range, so start on the 20 setting at first.
On my STi on stock suspension, I am running a Cusco rear bar set to the middle position. The car seems quite neutral with a bit of understeer going into higher speed corners. That will be fixed when I put my coilovers on!
Enjoy the track - it becomes addicting...
Old Jan 13, 2005 | 09:00 AM
BioMech17's Avatar
thanks egan
Slack
Nov 22, 2004 10:21 AM
wrxn'sx
Jul 18, 2003 07:36 PM
dan avoN7
Jun 26, 2003 12:41 AM
Zoeb2s
Nov 30, 2002 10:24 AM
