general brake question
Old Sep 9, 2004 | 11:40 AM
Benjamin Tang's Avatar
Car Info: 2003 subaru forester xs
having this problem with another car... front pads/rotors squeal when warmed up, and feel like there is a slight warp in them. they don't do it when cold, but the longer u drive the louder they get. if i am hard on the brakes, they are not noisy, but under light braking it's damn loud. when backing up in reverse, they sound "coarse", like sandpaper.
the pads/rotors have about 80% meat left in them, but i've tried everything the mechanics tell me... chamfered the pads, put lots of anti-squeal grease on the backsides of the pads, machined the rotors once, resurfaced them a second time... it always comes back.
was hoping someone out there might know something i don't... hoping i don't have to spend big $$$ on brand new pads/rotors
Old Sep 23, 2004 | 12:50 AM
WindingRoad's Avatar
Car Info: 2004 White GDB
maybe its not your brakes. It could some bearing somewhere.
Old Sep 23, 2004 | 08:29 AM
nic3krnnamja83's Avatar
i used to get a lot of peeblles stuck between the rotors, i used to take a knife and put it between and try and see if any were there usually there was and problem went away, maybe a solution to try
bartolommeff
Oct 13, 2003 02:14 PM
NY WRX
Apr 5, 2003 05:08 PM
ryanlb16
Mar 17, 2003 01:51 AM
littleredscooby
Dec 2, 2002 08:31 AM
