front or rear strutbar?
Old Oct 31, 2003 | 09:17 AM
ish's Avatar
ish
the front makes a more noticable difference imo
Old Oct 31, 2003 | 09:52 AM
platypus's Avatar
Car Info: dangerous with a wrench
Strut bars are not necessarily the first thing I'd upgrade on a suspension setup. With that being said, it's going to depend on what you'd like the car to do.
As with most suspension mods, if you're trying to get the car to rotate more (go from under to neutral/oversteer) then stiffen up the rear.
If you're trying to eliminate oversteer or twitchyness, stiffen up the front.
Old Oct 31, 2003 | 09:56 AM
wrexr's Avatar
Car Info: E28M5, RAM Powerwagon, Motos
IF you have a wagon, the rear would make a considerable difference. The sedan won't benefit as much. I would get an adjustable rear sway bar first, if you don't have one. Some end links too.
Old Oct 31, 2003 | 01:44 PM
bri's Avatar
bri
strut bars don't do anything. i had one on my integra. if you're talking swaybars get the rear.
Old Nov 10, 2003 | 07:19 PM
Salty's Avatar
Originally posted by NothingToLoose
rear strut bar made a heuge diff in my CRX and my friends probe GT. Its all up to the type of car. What year integra did you have.
i say rear too... any rear STB will be okay. if you get a Front bar gewt a whiteline ksb599
Old Nov 11, 2003 | 03:26 AM
Bagelw's Avatar
Car Info: 2004 WRX Wagon
What year is the Civic Si?
If it is a 99 or 00 model then the front should have a decent strut bar and sway bar. The rear lower sway bar is what you want to increase. The best way to go is to get an Integra Type R 22 mm rear swaybar with the beaks kit. Will make a huge difference in the way the car handles.
I would think the 03s would be the same deal but since it is a completely different car then it's hard to say. The main thing you want out of a FWD car is rotation from the rear which is what the larger rear swaybar will do for you.
Island Style
Hawaii Classifieds
Jul 23, 2013 09:13 AM
Island Style
Hawaii Classifieds
May 28, 2013 01:12 AM
turdb0
Mar 18, 2013 09:07 PM
Addicted2Racing
Apr 28, 2004 09:59 AM
KmanRuffian
Jan 7, 2004 06:45 PM
