Conventional Damper System v.s. External Reservoir Damper System
Old Sep 27, 2004 | 02:52 PM
My_Red_Suby's Avatar
Car Info: 2005 Metallic Gray STI
Thumbs up Conventional Damper System v.s. External Reservoir Damper System
Can you guys tell me a detailed info on what the differences are on the Conventional Damper System v.s. External Reservoir coilover system.
I have the TEIN Type Flex now & I would like to get a set of "racing only" coilover system...
Marky
Old Sep 27, 2004 | 07:42 PM
Imprezer's Avatar
Admin v2.0
Car Info: 02 Black Legacy GT
Some systems come with ext reservoir becasuse the shock requires more volume.
You will need it for 2 main reasons:
1. Shock body waaaaaaaay too short to have large volume (like on S2000)
2. For hardcore racing use where the oil heats up and more oil = less heat = shock absorber works better.
On a Subaru, the shock absorbers have pretty large volume. Plus, clearance is not really an issue so besides the shocks being nice and long, they are also pretty fat (in diam) especially in the rear. So, there isn't really need for ext. reservoir system on Impreza, unless you go rally racing and have like 20" or suspension travel. Only then your shocks will heat up and would benefit from ext. reservoir system.
That is what I have gathered from various sources.
Old Sep 29, 2004 | 12:00 AM
Lurk's Avatar
Try some Ohlins coilovers. Tell us how you like them. :thumbsup:
Old Oct 9, 2004 | 12:39 AM
18hrwrx's Avatar
Car Info: White on Gold STi
Marky
I talked to the ohlins dealer and he said the race coilovers for the WRC car would rip a part a daily driven car.
Old Oct 9, 2004 | 01:03 AM
Not if you have a WRC-style cage with strut top anchors.
2bluewagons
Dec 20, 2006 08:09 AM
2bluewagons
Oct 19, 2006 11:16 PM
HoneyRex
Dec 25, 2005 10:03 AM
laoba
Jan 2, 2005 05:28 PM
wrxless
16
Apr 27, 2004 08:39 AM
