Changing Brake fluid...
Old Oct 29, 2005 | 02:51 PM
c0neHead's Avatar
Car Info: 2006 Lotus Elise
I need to flush oem brake fluid and replace it with Motul RBF600. I thought I had several bottles around but I only have one. Is that going to be enough for the 2006 WRX?
On my previous car I had upgraded brakes so I flushed the fluid more than a year ago... I do not recall how much is needed.
Thanks.
Old Oct 30, 2005 | 01:18 AM
Wingless Wonder's Avatar
Origami posted by c0neHead
I don't have the braking system capacity specs for the '06 model but the '02 needs at least two 500ml bottles. I would have three bottles of the stuff on hand just to make sure you don't run out in the middle of the job.
Old Oct 30, 2005 | 11:41 AM
c0neHead's Avatar
Thanks. I figured so I did not even start bleeding the brakes. I am going to have to find somebody who has couple of bottles around so I can use them today since I have a track day tomorrow.
BTW, changing the pads on the Subaru 4-pots is a 45-min job. Easy.
woocabin
Dec 22, 2010 11:50 AM
JMeltzer4
Aug 17, 2010 07:23 PM
howzdawagon
Jan 23, 2009 10:24 PM
XxPLoSiVexAzNxX
Apr 11, 2007 01:33 AM
Slack
Jan 1, 2004 05:47 PM
