camber front and rear
Old Jan 23, 2004 | 09:27 PM
MO REX's Avatar
Car Info: 02 PSM WRX
I just installed SPT springs (1.4 in front, 1.2 in rear) and I was wondering if I should try to get the same amount of negative camber in the front as the rear. Whitelines wheel alignment specs show (sport -1.50 in front and 1.00-1.25). Why more in front than the rear? After alignment I ended up with around -1.12 in front and -2 in rear with no toe and the car handels great but I dont know if it could be better with a different combination. I also was wondering how much tire wear I should expect if I changed toe in rear to 1-2mm out ( I have so3s). If you guys have played around with different setups I would appreciate any input you may have. Im trying to save some money so I would like to keep the number of alignments to a minimum.
thanks
Old Jan 24, 2004 | 01:57 AM
dropkick_muppet's Avatar
Car Info: '03 PSM Sedan
running more camber in the rear than the front will tend to make a WRX understeer more. i run more front camber than rear in an effort to keep the front planted, and to get the rear to rotate.
Old Jan 24, 2004 | 02:29 AM
I have what many would consider an odd alignment, but it seems to work.
-------- Camber --- Toe
front ------ -1.6 --- 0
rear ------ -2.5 --- 1/16 out
I also have a Whiteline ALK, stock front sway + links, and FHI 20mm RSB with Whiteline solid endlinks. I can say that my car is pretty much the epitome of 'neutral' in high-speed corners. I won't change a thing for either street or track use, but I will be adding a Whiteline adjustable sway bar for autocross to get more rotation at low speeds. Oh, and I run on 215/45R17 S03s.
Old Jan 24, 2004 | 01:21 PM
MO REX's Avatar
I just looked on Oakos website and it said factory camber in rear is -1.5 (sounds high)and front is around -0.5. Do you guys know that these #s are correct and if so why is the factory camber set up this way? When I talked to my mechanic he thought negative camber in front wouldnt help understeer that much because the car is AWD. He also said that he hadn't done any custom allignments on AWD cars but when he did it on RWD cars they seemed to like more negative camber in the rear. He used to run the pit crew on an open wheel race car and has had experience with a couple Miatas. So what I am wondering is if you guys that have went to more - camber in front have personally noticed a difference in understeer.
Old Jan 24, 2004 | 01:34 PM
i'm currently running:
-1.0, 0 toe front
-.5, 0 toe rear
i have the whiteline ALK installed, and my cusco bar set to the middle of the three settings in the rear, with Perrin links. i'm also running STi V8 RA Spec-C struts, springs and tophats, plus a cusco front strut tower bar. oh yeah, i'm also riding on 17x8.5 gramlights with 225/45 S0-3s.
when i went to the new alignment, i noticed a significant decrease in understeer and the car became much more neutral. the alignment shop wasn't able to get more rear camber from my setup.
i have adjustable rear lateral links in my garage, so i'm going to get another alignment when i get them installed. right now, i'm thinking -2.0, zero toe up front, and -1.5 or so, with 1-2mm of toe out in the rear.
Old Jan 25, 2004 | 08:44 PM
Factory camber is only about -.5 degree MO REX. And adding camber up front does help understeer, as well as improving turn-in.
Old Jan 27, 2004 | 01:10 AM
babysmurf's Avatar
Car Info: '08 GT3/'08 Cayenne Turbo/'02 WRX Sedan/'95 E36 M3
i would agree with dropkick_muppet on the running more negative camber in the front, as that will help with the understeering tendencies of the wrx. i am currently running: -1.5 in the front and -1 in the rear, and my car handles quite well on the track. but i also have the cusco rsb set to the middle setting, coilovers, and whiteline alk.
Old Jan 27, 2004 | 11:25 AM
qwk_wrx's Avatar
Car Info: 05' Evo 8
i think i might try -1 in the rear i am currently on +1.5 in the front....
Old Jan 28, 2004 | 01:48 PM
i believe the rear camber on the WRX is adjustable, however the range of adjustment is rather limited -- based on my last trip to the alignment shop i prefer. i have a set of Hotchkis adjustable rear lateral links that i'm planning on installing in the car this weekend to rectify the situation.
Old Jan 28, 2004 | 03:30 PM
babysmurf's Avatar
on stock suspension, i dont' think the rear is adjustable... at least that's wut i was told the first time i took my car in for an alignment with springs..
Old Jan 28, 2004 | 06:20 PM
MO REX's Avatar
I was told the same thing so I am going to get a camber bolt kit from Whiteline. Thanks for the info guys, Im going to add a little camber in front, lose alittle in the rear and if the rear toe is adjustable (I think it is)I will go about 1-2 mm out.
Old Jan 29, 2004 | 02:48 PM
hmmm. that makes me wonder how the alignment shop that i went to adjusted the rear... oh well, they did a hell of a job, so i don't really have any complaints. tie to get the lateral links installed...
Old Jan 29, 2004 | 03:08 PM
david2z4's Avatar
From: Washington State, Car: 2000 Impreza Coupe RS-T T
Car Info: 2000 Impreza Coupe RS-T Tec3/Vishnu turbo Color: B
I have -2 front and -1.6 rear. 20mm rear bar, solid links front. DMS 50's I don't go into corners hot. I go in a bit slow and power hard thru the corner and out and it works for me.
Spring, dampening, bar size, tire pressure and driving style does make a differance on how much camber you will need to get the best patch on the road. So any one setting may work for one person but not the next.
Old Jan 29, 2004 | 08:44 PM
MO REX's Avatar
I dont go into the corners too hot either. Slow in fast out is what I have been told is the best so I may try a similar setting with alittle toe out in the rear. I will have my mechanic look alittle closer to see if he can adjust the rear of the car. Dropkick muppet, do you know where they did the adjustment. I am pretty sure there werent any eccentric bolts in the rear like the front on my 02 WRX. Any input would be appreciated.
Thanks.
