Brake System???
Old Nov 27, 2004 | 04:59 AM
4080wrx's Avatar
Brake System???
Does the 03 wrx brake system front and rear work together when you depress the brake pedal? or are they independent meaning the front brakes are controlled by the brake pedal and the rear are controlled by the emergency brake only? I know this sounds like a stupid question and i know that the second examlpe is more than likely the correct answer. I am just asking because i remember reading somewhere that if you were to replace the complete front brake system that you should also replace the rear also due to some kind of wear i'm not to sure so thats why i am asking.........thanks
bluesaint
Jun 1, 2006 02:23 PM
My_Red_Suby
Oct 9, 2004 01:03 AM
bambams247
Aug 26, 2003 05:06 PM
