Brake Problem
Old Oct 14, 2003 | 12:36 AM
First, check the vacuum line from the intake manifold to the brake cylinder to make sure there are no cracks or leaks. Then examine your rotors to see if they look flat and shiny liek they are supposed to. If you are still under warranty and that didn't work, take it to the dealer for an inspection. If you aren't, take your pads off, sand them, and turn your rotors.
STiNightFall
Nov 25, 2004 01:52 AM
razorlab
Apr 3, 2004 01:15 PM
impreza2002
Aug 18, 2003 09:12 PM
go go go
Apr 20, 2003 11:22 AM
