Brake light stays on
Old Jun 11, 2007 | 07:46 PM
nkghost's Avatar
Car Info: 2002 MBP WRX
Exclamation Brake light stays on
Hey guys,
For a while my brake light has stayed on, I recently did a whole new brake upgrade (stock size) slotted rotors, SS lines, new pads and I have brake fluid in there, for some reason, the brake light comes on when I start to move. Someone told me it might be a sensor gone bad? Any idea as to how much it would be to replace the sensor if it IS the problem?
Or any other ideas as to what it could be?
Brake fluid is not low at all..
Kevin
Old Jun 14, 2007 | 08:44 PM
Sti convert 07's Avatar
Car Info: 2000 chrysler
your brakes are not adjusted properly its actualy the parking brake, im in a brake class for auto service tech now and if you did a complete brake job it coud also be that you didnt bleed the system right check those first.
Old Jun 14, 2007 | 08:45 PM
ohh and test your pedal and list the feelings you get from it, is it overly stiff? or is it light, does it go to the floor all the way with little pressure or is it spongey?
Old Jun 14, 2007 | 08:46 PM
sensors are expensive in Florida they are upwards of 100 bucks and its fed law that they be in the car so DO NOT RIP IT OUT
WRXakaBooSTi
Jan 28, 2006 09:46 AM
Nick Koan
Rally
Nov 5, 2004 04:43 PM
bone324
Rally
Jan 29, 2004 03:57 PM
nywrxtasy
Jan 14, 2003 04:13 AM
