brake fluid color
Old Mar 28, 2005 | 07:12 PM
blaznasn's Avatar
brake fluid color?
i don't have my car with me, it's in the shop so i can't look. Can someone tell me the color of the OEM brake fluid? is it clear? and does it evaporate?
thanks
Old Apr 7, 2005 | 12:39 PM
i dunno about evaporation but its yellow ish i think
Old Apr 9, 2005 | 02:53 AM
It's a clear amber-yellow color, unless you've faded it badly, in which case it will turn murky brown.
Old Apr 9, 2005 | 10:40 AM
DrD's Avatar
DrD
Car Info: 2012 Legacy 2.5GT-L
clear, yellowish-brown (the color is part of the DOT 3 and DOT 4 specs, so they are all the same - there are other fluids which are different, such as ATE superblue, and while it is essentially a DOT 4, it doesn't meet the spec (because of the color only)) - it will become increasingly dark as it absorbs water out of the air.
the evaporation rate is negligable - however, as your brake pads wear down, the fluid level will drop (since the cylinders are extended further)
JMeltzer4
Aug 17, 2010 07:23 PM
RavSpec
Apr 15, 2006 09:13 AM
mbquarts
Nov 2, 2005 03:22 PM
StopTech
Sep 3, 2003 01:32 PM
