Best Brake Combo Recommendation
Old May 1, 2003 | 06:20 AM
subaWRXtasy's Avatar
Car Info: Red 2002 WRX
I am looking at the following choices:
1) Stop Tech Slotted with Metal Master Pads - $469
2) DBA Gold with Metal Master or Hawk Pads - $550/$630
3) DBA Slotted with Metal Master Pads - $449
4) OE slotted Frt with Brembo Rr and Metal Master Pads - $499
5) Stock rotors pads - $320
What is everyone's recommendation on these choices or add additional choices - key is maintaining stock wheel size (winter wheels)
bws
Old May 1, 2003 | 02:52 PM
Good point on the car info. I thought my user name gave enough lead. No autox but a some track days here and there. I am with you on the temp thing but I drive the car very hard as a daily driver. I have run metal master, mintex, pagid, all before on similar situation cars. Love the pagids but they are a bit more expensive. I would like to step up from the stock fronts, rear stock does seem OK though. Actually I just bought the DBA slotted rotors and now on the hunt for pads. I may do the steel braid lines a little later. Any pad recommedations. Stock have worked fine for me but I thought I would try something different. The metal master (axxis) are very affordable but I am concerned about cleaning the dust off the wheels every day.
bws
Old May 1, 2003 | 02:57 PM
One more point, I ran a few track events already on the stock set up. The stock parts worked OK they are just worn out (22K miles) now. I do tend to trail brake so I was not necessarily focused on excessive fade if it was There. I will see what something different will do.
bws
dgcom
Jan 16, 2011 05:21 PM
gruppe-s
Engine and Drivetrain
Mar 2, 2007 06:23 PM
jc5d5d
Mar 11, 2004 03:51 AM
