Bearings and Brakes
Old Sep 17, 2003 | 10:58 AM
Gunslinger's Avatar
Car Info: '02 Subaru Impreza WRX
Bearings and Brakes
I have a friend with a 1996 Subaru Legacy Wagon. She just had her front brakes replaced a week ago and is now having a hammering noise in the front possibly right wheel. She has been told it is a wheel bearing problem.
Could this problem have been caused by the replacement of the front brakes?
Old Oct 1, 2003 | 09:08 PM
ImprezaVA's Avatar
Car Info: 1998 Subaru Impreza L 2.2
Jack that wheel up and test it. Grab the top and bottom and see if you can move the whole wheel & tire in and out. It shouldn't have any free play, and if it does replace the bearing before it ruins the spindle.
*If it is the wheel bearing, do not torque the lateral link bolt with an impact wrench. This is the problem with our wheel bearings going out, at least that's what Subaru is saying. It supposedly warps the bearing housing when over torqued.
Torque the lateral link to 101 +/- 14 ft. lbs. for Impreza's.
Axle nut: 137 +/- 14 ft. lbs.
Brake caliper mount: 38 +/- 4 ft.lbs
Also, this is a good link for everyone to read:
http://www.endwrench.com/current/Cur.../WhBearRep.pdf
and...
if you haven't checked out www.endwrench.com, do so.
-Charles-
salvator_rizzo
Jul 20, 2009 01:08 PM
reddevil
Jul 29, 2007 07:40 PM
AMS
Jul 27, 2007 09:10 AM
suby_dude
Vendor Group Buys/Specials
Aug 23, 2004 12:59 PM
Lam
Apr 7, 2003 05:27 PM
