air ride suspension problems
Old Sep 18, 2003 | 08:08 AM
alosix's Avatar
Is this a factory suspension or something aftermarket? I don't run one of these on my WRX, but I do have a pretty complicated system on my Jeep,so I might be able to help troubleshoot it.
They way the rear is acting I would start checking for air leaks. Does the system have height sensors or is it controlled by air pressure.
Do you know what the air lines are made of/what type they are. If they have NTP connectors or use DOT air brake tubing I might be able to give you some hints on what to use to get the airbags/struts filled manualy so you can drive it.
Jason
Old Sep 19, 2003 | 06:42 AM
alosix's Avatar
Ok.. At least they are ntp fittings. For a somewhat inexpensive way to get it moving, this might help.
http://www.offroadonly.com/cgi-local...2ef+1064002391
You might also need another NTP fitting that will fit your struts, and a short length of hose.
If you really felt like going nuts I'm sure the guys that work on that system could adapt it to work on a subi. It can make my lifted Jeep corner flat because of the computer control.
I would probably first check into the height sensors. If they are not working properly the system probably won't attempt to fill the struts.
Can you find a factory shop manual for this car? I'm sure it would have some troubleshooting help for this.
Jason
Old Sep 19, 2003 | 12:46 PM
Try the Ultimate Subaru Message Board. They talk about those air springs like we talk about transmissions here.
xabre1200
Oct 5, 2015 12:02 AM
usaf126
Hawaii Classifieds
Aug 18, 2014 02:01 AM
grex767
May 27, 2006 10:37 AM
werx_racing
Hawaii Classifieds
Mar 8, 2005 03:05 AM
