Racecomp's 'Financial Crisis, Buy Parts To Help The Economy' Sale!!!
Old 10-14-2008, 09:54 AM
Former Sponsor
Racecomp Engineering's Avatar
Car Info: every subaru ever
Since the economy is in a panic and the stock market is in a freefall, here at Racecomp, we have decided to prolong and also pass along new savings to our customers. We call it the 'Financial Crisis, Buy Parts To Help The Economy' sale.
Racecomp Engineering 04-07 STi Swaybars
We didn't try to reinvent the wheel here, just provide another option for GD STi owners looking for a swaybar set that will work well with stock springs, lowering springs, or coilovers. The settings for the front bar are 25.5 and 28.5mm, rears are adjustable from 25.5, 27.0 and 28.5mm. So you could run these and not have to go to a bar that is actually 27mm thick.
Specifications:
25.5mm physical diameter
4142 Chrome Moly
Heat treated and cold finished.
Ends are hot forged on a 125 ton press.
Front and rear adjustable.
Washer tabs on front and rear to prevent walking
$199 plus shipping for each bar or get both front and rear for a special intro price of $360 plus shipping
*NOTE* We have a limited number of rear prototype bars that are 25.5mm NON-adjustable for $120 shipped.
Racecomp Engineering GD Chassis Front Camber Plates
FINALLY BACK IN PRODUCTION!!! These front camber plates were designed to be used with stock springs, lowering springs or coilovers. Made of aircraft grade T6 7075 alloy, these units alow up to -3 degrees of camber. We use one of the highest quality race bearings available, with a radial load of 6900 pounds. These come in two varieties, lowering and non-lowering.
$499 shipped
Racecomp Engineering GD Chassis Lowering Springs
Our trademark lowering springs are as popular as ever and we are going to continue our summer long sale on our full lineup of springs.
Spring Rates and Drop:
295/275 23/20mm - Yellows
285/269 15/10mm - Blacks
278/259 30/15mm - Wagons
Yellow Springs and Black 'Regular Guy' Springs - $309 shipped
Wagon Springs - $249 shipped
Yellow Springs Pictured Below
Racecomp Engineering Tarmac Zero Coilovers
Our new, more affordable coilover based on our highly successful RCE Tarmac 2s.
Built by KW Suspension in Germany to our specs, these use the same high quality stainless steel corrosion resistant construction as our RCE T2s.
The difference here is our Tarmac Zeroes have preset damping that maximizes both performance and ride quality. This allows the end user to just put them on and drive without worrying about playing with too many adjustments. It also keeps them more affordable. Ride height is still adjustable of course. Can be used with camber plates or Group N strut top mounts. Here is one of the reviews you will find about these: http://www.iwsti.com/forums/2006184-post4.html
Linear spring rates:
400 lbs/in front
340 lbs/in rear
$1599 for coilovers only (no strut top mounts included)
$1999 shipped and assembled with Group-N Front and Rear Mounts
$2149 shipped and assembled with Cusco Front and Rear Camber Plates
Racecomp Engineering Tarmac II Coilovers
Our most popular coilover option. Designed for those who autocross or track their cars on a frequent basis. Amazing performance without sacrificing ride quality. European valving at its finest.
Separate bump and rebound adjustability
500 lbs/in front and 400 lbs/in rear spring rates
Custom spring rates available
ASSEMBLED AND PRESET RIDE HEIGHT AND DAMPING
$2649 shipped and assembled with Group-N Front and Rear Mounts
$3099 shipped and assembled with Vorshlag Front and Rear Camber Plates
$3169 shipped and assembled with RCE Front and Vorshlag Rear Camber Plates
AST 4100 Coilovers for GD
One of the best daily driving combinations available. Easy to adjust, nice comfortable ride with a significant increase in handling.
390 lbs/in front and 280 lbs/in rear spring rates
Single adjustable damping
$2149 shipped (no strut top mounts included)
$2899 shipped and assembled with Vorshlag Front and Rear Camber Plates
Ohlins Fixed Perch Struts
The ultimate fixed perch strut solution for the GD chassis. The holy grail of suspension comfort. Here is the answer to all your strut clunking woes. The Ohlins can be matched up with a wide range of springs, anything from stock springs to Arai Tarmac springs. We have settings for them all.
$CALL for NEW special pricing
Racecomp Engineering is offline
Old 10-14-2008, 09:55 AM
Former Sponsor
2008 STi Parts Post
Racecomp Engineering Clubsport Coilovers by KW
Racecomp Engineering is proud to announce their Clubsport Coilovers for the 2008 STi! One of the most anticipated suspension options for the new body style Impreza is available now!
These are a true 2008 STi Impreza fitment with valving and spring rates specific to the completely new 2008 chassis. These are not cobbled together from existing parts....these are designed from the ground up to provide a track worthy, easily serviceable and long lasting threaded body coilover suspension system for the 2008 STi.
These coilovers feature the same inox-line stainless steel corrosion resistant construction as previous versions of KW suspensions. Spring rates are 8kg front and 8kg rear. These are aggressively valved, 2 way adjustable, performance coilovers. These are valved more aggressively then the standard KW Variant 3's, yet still offer an amazing ride quality not felt with other brands. These do not come with strut top mounts, but we have a few options available.
$2295 shipped for coilovers only
$2570 shipped with Group-N front tops and STi rear tops, fully assembled
$2655 shipped with Cusco front camber plates and STi rear tops, fully assembled
Ohlins Sportline DFV Coilovers
Ohlins has announced their new DFV Sportline Height Adjustable coilover suspension for the 2008 STI.
Long known for their excellent racing and street dampers, Ohlins is now able to offer a street/track solution for the new 2008 Subaru Impreza.
Highly flexible damping range allows for comfortable street ride and excellent track performance. New DFV (Dual Flow Valve) technology allows for more advanced valving on both the rebound and compression side, resulting in even better ride quality and performance. A first for Ohlins Sportline on a Subaru, these coilovers are dual height adjustable, allowing separate preload and ride height adjustments.
Combined with the 2008 Impreza's redesigned rear suspension, Ohlins is able to take the tenacious grip offered by the new STI one giant step forward, while allowing the user to fine tune the balance and handling of the car.
*Includes front camber plates and rear pillowball top mounts
*Separate ride height and preload adjustment
*Spring rates are 500 lbs/in front and 400 lbs/in rear
*Custom spring rates and valving are available
$3299 shipped
Racecomp Engineering GR Chassis Camber Plates
Based off of the highly successful GD style RCE camber plates, we have extended our lineup to include the GR chassis. Basically identical to the previous generation's camber plate except for the obvious new strut top design that came along with the new chassis. These will be offered in both lowering and non-lowering versions. We are accepting preorders now for these which will be available shortly.
$499 shipped
Racecomp Engineering GR Chassis Sway Bars
These are in the works, more information to follow shortly. Please give us a call to discuss what we have planned and to get on the preorder list.
Whiteline GR Chassis Sway Bars
Whiteline 22mm Front Adjustable Sway Bar - $175 shipped
Whiteline 24mm Front Adjustable Sway Bar - $197 shipped
Whiteline 20mm Rear Adjustable Sway Bar - $197 shipped
Whiteline 22mm Rear Adjustable Sway Bar - $197 shipped
Cusco GR Chassis Suspension Parts
Cusco OS Front Strut Tower Brace - $168 shipped
Cusco Type-2 Front Lower Arm Brace - $170 shipped
Former Sponsor
Package Deals Post
Tarmac 2's in action
2008 STi Feel Good Package
Kartboy Pitch Stop Mount
Whiteline Steering Rack Bushings
Whiteline Anti-Lift Kit
Whiteline 22mm Adjustable Front Sway Bar
Whiteline 20mm Adjustable Rear Sway Bar
Cusco Type-2 Lower Arm Brace
$799 shipped
Package 1
RCE Yellow or RCE Black Springs
RCE Front Camber Plates
$749 shipped
Package 2
RCE Front Sway Bar
RCE Rear Sway Bar
Kartboy Rear Endlinks
$1249 shipped
Package 3
RCE Front Sway Bar
RCE Rear Sway Bar
$1609 shipped
Old 10-14-2008, 09:56 AM
Former Sponsor
Racecomp Engineering Kool Brake Kit
This kit was designed to cool and vent the braking system, thus reducing rotor temperatures. Initial testing at Summit Point Raceway showed up to a 200° F drop in rotor temperature when using aggressive pads. Testing was done with Pagid Blue RS-42, Pagid Yellow RS-19 and the new RS-29 brake pads. Designed to work with both stock STi rotors and any aftermarket 2 piece rotor, this kit is available now.
The Kool Brake Kit includes 12 feet of high quality, motorsport grade, high temperature hose far better then other options on the market. There is no need to upgrade. Stainless steel hose clamps are also included.
The RaceComp Engineering Kool Brake Kit is now exclusively offered in dry carbon fiber to improve unsprung weight savings. The spindle ducts are considerably lighter then the OEM dust shields that are replaced during installation.
Current applications are 2004-2007 STi.
2008 WRX and 2008 STi applications coming soon!
$339 shipped
Pagid
4-2-1 - Black - Street - Front and Rear Set - STi - $439 shipped
RS5 - Blue - Tarmac Rally/Track - Front and Rear Set - STi - $444 shipped
RS29 - Yellow - Track - Front and Rear Set - STi - $538 shipped
Off of a 2006 Spec C STi, these struts have 4 clicks of adjustment. Fits 05 and up STI only. $500 + shipping
Old 10-21-2008, 07:45 AM
Former Sponsor
bump.....suspension is our specialty
Old 12-15-2008, 10:31 AM
Former Sponsor
Warm day in December here in Maryland
STi4WRC
03-24-2009 11:47 AM
kenji815
12-30-2008 12:05 AM
LxJLthr
10-08-2008 11:17 PM
STi deede
07-27-2005 03:48 PM
Quick Reply: Racecomp's 'Financial Crisis, Buy Parts To Help The Economy' Sale!!!
