reset ecu for higher octane fuel?
Old Nov 19, 2004 | 12:05 PM
amarpauld's Avatar
Car Info: Hyundai Pony
ok I had been using regular fuel (86 octane i think?) for a while and then switched over to 91.. I recall hearing somewhere that you need to reset your ecu by disconnecting the negative terminal of your battery for a few minutes and then putting it back on so the ecu will 'adjust' to the new octane level... is this true??
Old Nov 19, 2004 | 01:04 PM
Mulder's Avatar
Car Info: 02 WRX WRB
Or, you can do nothing. The ECU is constantly "learning" and will adjust to the higher octane fuel as you drive. Resetting will clear out the adaptive cells and return them to their default settings, forcing the learning process to start over. Whether you reset it or not, it will eventually end up the same after enough driving.
Old Nov 19, 2004 | 11:42 PM
nic3krnnamja83's Avatar
86? u dont drive a turbo car do u? guessing since its lower then what u should be putting in. and no unless u use anything over 93 i dont think ecu is a problem.
Old Nov 20, 2004 | 11:15 AM
amarpauld's Avatar
it is a turbo.. ive used a tank and a half of regular in it (when i initially got it... I dont know what the previous owner used..) then i switched over to premium..
Old Nov 20, 2004 | 12:09 PM
then just always use premium, no worries after that unless u use race gas or the such
Old Nov 20, 2004 | 11:52 PM
v rod's Avatar
Car Info: Real Slow
Angry my g/f somehow accidentally put in 87 regular, full tank!
yes, i was pissed! i drive it and the engine was pinging like a ****. i go straight to a 76 gas station and put in half tank 100 octane. that was expensive. i took it easy for a couple miles and then gradually getting on it listening for knock. it seemed to go away so i start going wot. ecu started learning i guess and gave some timing because the car started pulling harder.
i'll prolly disconnect the battery tomorrow and beat on it for good measure. actually, i should pull the plugs to see how bad the det. was first.
Old Nov 21, 2004 | 04:10 PM
Jesse00's Avatar
Car Info: 2002 Subaru TS
or you can pump out the gas your gf put in your car out and pour a 91 in instead.
0260B4U
Feb 6, 2004 06:12 PM
johndoe
Feb 2, 2004 03:56 PM
mmboost
Aug 18, 2003 01:45 PM
joltdudeuc
14
Mar 25, 2003 05:14 PM
blackwagonrx
Mar 1, 2003 01:41 AM
