Problems after replacing the fuel filter and spark plugs. Please Help!!
Old Feb 28, 2005 | 07:47 AM
HellaDumb's Avatar
Car Info: 72 Vespa with curb feelers
What do you mean it will idle but not start? Did anything out of the ordinary happen during the install? (i.e. did you accidentally arc the positive terminal on anything, did you possibly mis-gap the plugs?)
What year/model is it?
Originally Posted by fokyc
I've run into some problems after replacing my fuel filter and spark plugs. Yesterday, after removing the battery for easier access to spark plugs and replacing them along with my fuel filter I could not start the car. The car idles but doesn't start. It appears that the fuel pump is working (buzzing) but there is no fuel pressure in the line to the filter. I took the fuel line off the filter while my friend was trying to start the car.
Old Feb 28, 2005 | 08:16 AM
soggynoodles's Avatar
In order for the car to idle it has to start up. How is your car idling but not starting
Maybe I'm reading this wrong...
Old Feb 28, 2005 | 08:31 AM
I am sorry, I meant it cranks but doesn't start.
Did you check the spark plug gaps?
Did you double check your connections?
Old Feb 28, 2005 | 07:14 PM
HomerJay's Avatar
Car Info: MY00RS25
Sounds like fuel pump to me. Have your battery checked and clean all the wires. I doubt that's the problem, sounds like fuel delivery problem. Undo the fuel filter and see if fuel comes out. If the pump is working it should have pulled fuel into the filter and it should be full,
Old Mar 3, 2005 | 01:32 PM
HellaDumb's Avatar
I did do that and the filter as well as the tubing is completely dry. When the ignition is on and I push the gas pedal the gas pump makes a buzzing and hissing noise. Any other ideas?
I'd put back in the old filter. Maybe you got one with a defect.
Old Mar 3, 2005 | 01:44 PM
sykosis's Avatar
Dumb question but... is it on backwards
i<3dirt
Oct 20, 2014 10:26 AM
t3ch9
Jun 15, 2009 11:22 PM
williamrt77
Forester General
Sep 29, 2007 06:08 AM
DetailAddict
Oct 21, 2005 03:11 PM
mexicanpizza
Sep 20, 2004 09:14 AM
