Oil leak
Car Info: 2004 Impreza WRX
Oil leak
Just recently I noticed an oil leak. I take it into the dealership to find out its something to do with the oil switch and when the engine was built in the factory a hole was drilled to far or something. So a new engine is being ordered and with only 6,000 miles they are swapping the engine.
Hopefully the rest of my future will be a pleasant one!
just got the car back, apparently they replaced the short block assembly.
however, i now notice radiator fluid leaking/dripping in two spots
not happy at all!
not happy at all!
not happy at all!
not happy at all!
Where to start:
1. First with about 500 miles on my wrx the cd changer got stuck, the dealership had to order a new one and replaced it under warranty.
2. About a month after having my wrx, on my way home from work I get rear ended because of some idot who was fooling around with his radio. Not to worry though the car is fully repaired but I'll always know it was hit. Despite I WILL NEVER EVER USE ROBBIES AUTO REPAIR IN DOVER NJ EVER AGAIN.
3. Just recently I noticed an oil leak. I take it into the dealership to find out its something to do with the oil switch and when the engine was built in the factory a hole was drilled to far or something. So a new engine is being ordered and with only 6,000 miles they are swapping the engine.
Just got the car back, apparently they replaced the short block assembly.
4. I now notice radiator fluid leaking/dripping in two spots
For be a first time suby owner it has not pleasant.
a lemon is the same problem over and over and over again (total of three times)...
this is just diffferent problems left and right.
does anyone have any suggestions..ie could i expect to get a new car?
Originally posted by Jgrahn555
Where are the two points it is leaking?
