Oil Changing??? Help!!!
Old Sep 23, 2006 | 04:01 PM
JDM_WRX_FREAK's Avatar
Car Info: 2005 Subaru WRX
Exclamation Oil Changing??? Help!!!
Sup Tuners well I been wondering what type of Oil Filters and Oil do you guys use when changing your Oil? I don't know what the numbers means like (5W-30) or (10W-30) when changing your Oil, can anyone tell me and what Oil Brand to use for my 2005 Subaru Impreza WRX.
Old Sep 23, 2006 | 05:04 PM
Mulder's Avatar
Car Info: 02 WRX WRB
Those numbers are oil viscosities.
If you refer to your owners manual there is a section that explains what the oil specifications mean, and shows the recommended grades and viscosities that you should use. Just follow those recommendations.
As for brand everyone has their preferences, but the important thing is to use an oil that meets the requirements. Brand is secondary in importance.
Old Sep 25, 2006 | 09:24 PM
pooster.online's Avatar
Car Info: 2004 Java Black Pearl STi
use a synthetic oil like mobil 1.
Old Sep 25, 2006 | 09:33 PM
A.V.E.'s Avatar
as for filters, i use regular oem filters. you can purchase a 6 pack of filters from subaru genuine parts with crush washers if you need them.
look into a fumoto valve too, this will make oil changes a lot easier and cleaner. no need to remove the drain plug nor replace your crush washer.
at the moment im using castrol gtx 10w-30 oil. ill probably change to synthetic sooner than later and yes mobil 1 is what the majority of us use.
-Ave
Old Sep 28, 2006 | 07:41 AM
Roo's Avatar
Roo
Forester Specialist
Car Info: '98/'04 Foresters (S & XT)
-Ave
That's why I stock the Fumoto valves.
Old Oct 4, 2006 | 09:13 AM
Deserted1's Avatar
Car Info: 06 STi
when installing the valve do you use a stock crush washer, or just the paper one that comes with it?
Old Oct 9, 2006 | 09:20 AM
j*bishop's Avatar
Car Info: ass, grass or cash. no one rides for free
i used the one that came w/the valve.
Old Oct 9, 2006 | 11:31 AM
Either one will be fine, since it won't be loosened after you install it.
BlueSti389
14
Feb 12, 2004 09:09 AM
SHADO
Dec 15, 2003 12:15 AM
soso3
May 10, 2003 10:47 PM
BongMan
Jan 13, 2003 11:18 AM
