Hmmmm, clutch problem or up-pipe?
Old Jun 7, 2006 | 09:29 AM
Special---K's Avatar
Car Info: '03 WRX Yellow
Exclamation Hmmmm, clutch problem or up-pipe?
03 WRX sedan with 52 thousand miles
I had the 30K service and a Helix up-pipe put in by LIC quite a while ago. Never had any problems until now.
If I'm on the freeway and going about 60, I shift up from 4th to 5th, give it a little gas and the RPMs go WAY from about 4K to 7K up and then come down to normal. Then I smell something burning that reminds of a burnt clutch....but I don't have clutch problems in any lower gears when just driving around.
Any ideas? Is the Up-pipe leaking maybe after all this time?
Old Jun 7, 2006 | 09:37 AM
Imprezer's Avatar
Admin v2.0
Car Info: 02 Black Legacy GT
If your clutch pedal is released, you are gunning it and not going anywhere while the RPM go up, your clutch is dead.
Leaky uppipe would not cause that.
Old Jun 7, 2006 | 09:44 AM
that's what I figured it would be but does it make sense that that does not happen in lower gears?
Old Jun 7, 2006 | 10:10 AM
LICmotorsports's Avatar
Former Sponsor
From: 865 A Sweetser Ave.Novato, CA (new shop smell too)
Car Info: MY04 STi some call it a race car
Email sent...
Old Jun 7, 2006 | 10:15 AM
Quick response!
Hey LIC is awesome...what else can be said?
Old Jun 7, 2006 | 10:32 AM
Wingless Wonder's Avatar
Origami posted by Special---K
...but does it make sense that that does not happen in lower gears?
It makes a lot of sense. The engine and drivetrain, including the clutch, experiences greater load in the higher (numerical) gears. That's why it's very difficult to move from a dead stop using 5th gear - without the additional torque multiplication of the gear ratios, the load is too much. This is also why that if your engine experiences detonation, it most likely will occur in the higher gears.
Old Jun 8, 2006 | 12:07 AM
Boost Addict's Avatar
your clutch is just slipping.. haha, any reason you may have thought it was the uppipe???
Haole-Pino
Feb 3, 2006 02:46 PM
gpatmac
May 21, 2005 02:16 PM
gpatmac
Feb 14, 2005 12:11 PM
zumnwrx
Aug 19, 2004 02:14 PM
Kevin M
Jan 12, 2003 02:12 PM
