Help, my battery is dead, any warranty for it?
Old Nov 18, 2004 | 02:42 PM
EricDaRed81's Avatar
Dirty Redhead
From: Commuting? I don't know what that means anymore.
Car Info: 05 WRX Wagon (Crystal Gray)
The battery has a warranty but it doesn't cover the full cost.
If you look in the warranty booklet you'll see it's covered for 100% of the cost up to 12,000 miles then the coverage goes down by percentages after that.
Old Nov 18, 2004 | 05:13 PM
brentlz's Avatar
Car Info: 2002 Impreza WRX
Have you checked the fluid level in the cells? Don't overlook the obvious, like I did at first. Mine started to "die" around 20k miles and I was all set to go get a replacement...after finding several cells majorly low on fluid and then adding some distilled water to bring them back up to snuff, it has been fine for the past 12k miles. I've since added "check the batt fluid level" to my oil change service list...
Brent.
Old Nov 19, 2004 | 11:45 PM
nic3krnnamja83's Avatar
always let ur car get its brain warmed up before starting, meaning two clicks wait for everything to settle and turn
Old Nov 22, 2004 | 12:42 PM
gzichy's Avatar
Car Info: 2002 Subaru WRX
Unhappy
Originally Posted by fuzzymemory
Are there any classic WRX warning signs of when a battery is about to go? I've owned my 04 WRX Wagon for 4 months now (11k+ miles) and in the past few weeks, the car has been harder to start. Every so often it will hesitate to start. I was wondering if some of this had to do with the 25-degree mornings in New Hampshire or if this is a problem I should have looked at by my dealer.
I have a 2002 WRX and I live in Calgary (Canada) where it can get very cold. I also just started to notice that the car has a harder time starting when the temperature is below freezing. First off, make sure your battery fluid is up to full level. If not, fill up all the compartments with distilled water. Seconly, let your fuel pump pressurize the lines by turning your ignition on and waiting unil you hear the pump turn off (about 3 seconds). Lastly, plug in your car if you have a block heater. This makes a huge difference.
As for myself, I purchased an Optima Red-Top battery but I had to return it because it wasn't the the 35R (reverse style) and the positive lead didn't reach.Poo...going back to get the right one.
Old Nov 22, 2004 | 02:57 PM
Mulder's Avatar
Car Info: 02 WRX WRB
Read my post above, you could have used that Red-Top with a cheap replacement starter cable. Not sure how things are in Canada, but I'm not aware of any stores here that stock the 35R, they only sell the 35/75. Probably because it fits more cars. If you really want the 35R you may have to get it online.
Old Nov 26, 2004 | 02:16 PM
alvatune's Avatar
Car Info: 2002 WRX Aspen White
Smile Finally, i had my battery replaced!!!
Thank you for all ya inputs!!!
I got a brand new oem battery from the dealer!
-Al
Old Nov 26, 2004 | 02:30 PM
dust12's Avatar
Car Info: 2002 WRX
Good job Al. Glad to hear the good news.
Old Nov 26, 2004 | 03:49 PM
pmartell12's Avatar
Car Info: 02 Blue WRX
My battery in my 02 wrx was pooched. The dealer told me that it was a Pro-Rated Warranty, and I would be better off to go aftermarket.
I got a Optima 35 red top from wal mart (for $138 Canadian,) and layed it on it's side with the optima's terminal posts facing the driver. I bought some gold terminal posts from a stereo shop, threaded them into the battery's "side terminals" and hooked up my wires.
Been in for 3 months, faster starts, and my volt meter doesn't dip as low when my bass hits at high volumes.
chubs22
Mar 8, 2008 07:30 PM
Imprezer
31
Oct 24, 2005 02:28 PM
amnzamudio
Apr 8, 2004 05:07 AM
roadr8cer
Jan 23, 2004 04:41 PM
ImprezaRSX
May 24, 2003 08:14 PM
