Help! CEL P1507 - Idle control System Malfunction
Old Apr 21, 2005 | 03:06 PM
maruto's Avatar
I just got the CEL P1507 - Idle control System Malfunction on my 02 Impreza RS. Anyone know what could be causing that to come on and how to fix it? Is it something serious or minor? Thanks for any help!
Old Apr 21, 2005 | 03:13 PM
Mulder's Avatar
Car Info: 02 WRX WRB
This usually indicates a problem with the idle air controller (IAC). Often the solution is to remove the IAC and clean it with throttle body or carb cleaner.
If your car is still under the 3/36 warranty this should be covered, otherwise you can do it yourself or have a local shop do it.
Old Apr 22, 2005 | 03:44 PM
maruto's Avatar
Thanks, I'll try that.
Old May 9, 2005 | 10:10 PM
subyduuuude's Avatar
Car Info: ..........
yup, carb cleaner worked for a couple ppl i know....although when i had that code pulled and tried the carb cleaner I wasn't so lucky...I had to replace the whole idle air control sensor $$$$= , hope it works for you
Old Dec 18, 2005 | 07:32 PM
maruto's Avatar
took it in to the dealer under warranty as suggested. they replaced the idle air controller for free but that didn't solve the problem. when i took it back again they talked to the national service center and the solution, as crazy as it seems, was to replace the neutral shift positioner. worked like a charm.
BeE_JiZZeLs
Jun 7, 2012 10:42 PM
smr_wrx
Aug 1, 2008 10:02 AM
MaVz
Dec 27, 2005 01:13 PM
Valaar
Apr 23, 2005 03:31 PM
