Connected battery wrong. Car won't start Need help
Old Nov 22, 2004 | 02:54 PM
Mulder's Avatar
Car Info: 02 WRX WRB
Are you sure you checked ALL the fuses? There are some large main fuses in the underhood box that don't look like regular fuses, they are square and look a bit like relays. You may have blown one or more of those.
Old Nov 22, 2004 | 03:49 PM
nic3krnnamja83's Avatar
blown alternator?
Old Nov 22, 2004 | 07:18 PM
Mulder's Avatar
Yes it's certainly possible the ECU was damaged. However that wouldn't account for why the engine won't even crank, that is a basic electrical issue that has nothing to do with the ECU. Chances are that if you can get the car to crank it will probably start.
Did you check the fuses by eye or with a meter? You can't always tell by looking, they should be tested electrically.
Old Nov 23, 2004 | 10:36 PM
zunus's Avatar
check power, see if its at the starter if not, trace it back to the battery and find out what the last place you have power is.
Better yet, try a new battery. I have seen batteries that show power but are really dead. Small amp draws will still work but large amp draw gives you nothing. Thats my best guess, battery got fried
Old Nov 24, 2004 | 02:07 AM
traffic's Avatar
Car Info: 2004 PSM Impreza WRX
i was working on my friends crx today and did the same thing. checked the fuses and his battery fuse was out. replaced it and everything was back to normal.
Old Nov 24, 2004 | 10:38 AM
nhayden's Avatar
Car Info: 2004 Impreza 2.5TS
Check the service manual as well. There maybe several fusible-links in the main wire harness. These are thin wires that act like fuses and may burn out under an extreme condition such as connecting the battery wrong.
I know many aftermarket electronics are equipped with a reverse connection protection. Typically this is a small diode near the power terminals in the device and this will burn out when connected backwards. This is an inexpensive way to protect 12v electronics although it is a hassle to repair it is far cheaper then a new device i.e.... amplifier or radio. Not sure about the factory electronics though.
You may have also burned out the starter when this happened and that would explain why you get nothing when trying to start the car.
Break out the volt meter and start checking the fuse boxes. I have come across many fuses that look good in appearance but are open when tested with a meter.
peterislazy
Aug 15, 2008 09:32 PM
fm725fm
Oct 23, 2007 07:23 PM
dodgedakota
Sep 18, 2005 03:08 AM
EddyRS
Oct 18, 2003 01:29 PM
