Check Engine Light???
Old Jun 21, 2007 | 08:51 AM
gtfaded's Avatar
Car Info: 2002 wrx
Angry Check Engine Light???
i have a check engine light on with no symptoms, about a quart low on tranny fluid, took to auto zone to get a code and they said that it wasn't giving a code. Recently ran about 2 quarts low on oil for about 6 weeks maybe, added oil checked all other fluids, accelerates well, and idles well. Any suggestions before i go give a buncha cash to tha dealership.
Old Jun 21, 2007 | 10:32 AM
Mulder's Avatar
Car Info: 02 WRX WRB
Doesn't make sense that they found no code. Is it on steadily all the time, or flashing?
The low fluids, while not a good thing, would have nothing to do with the light coming on.
Old Jun 21, 2007 | 10:35 AM
doobyscooby's Avatar
Car Info: 2005 WRX
any mods?
Old Jun 21, 2007 | 10:45 AM
gtfaded's Avatar
Car Info: 2002 wrx
not flashing, steady on, mods are 2 in uppipe, downpipe, catback exhaust, k&n drop in filter, and re flashed ECU w/ passive boost solinoid emulator. but iv had those mods for more than 3 months and noo problems.
Old Jun 21, 2007 | 01:41 PM
gtfaded's Avatar
Car Info: 2002 wrx
it turned off for a while and then came back on.
Old Jun 21, 2007 | 08:05 PM
Mulder's Avatar
You need to find someone with a better scanner. The one at Autozone might not be able to read certain manufacturer-specific codes. Maybe check in with your regional forum, try NASIOC as well. Someone nearby is bound to have a scanner that can pull those codes. I'd help but I'm in NY, a bit far.
Old Jun 22, 2007 | 11:39 AM
whtwrx1991's Avatar
Car Info: 2005 STI
maybe an oxygen sensor, that light not flashing would have to do something with emissions.
Old Jun 22, 2007 | 03:12 PM
Mulder's Avatar
When the light is flashing it indicates a real-time misfire. If it is on steadily it means that a code has been stored for one of over a hundred possible parameters.
Old Jun 22, 2007 | 10:20 PM
gtfaded's Avatar
Car Info: 2002 wrx
dealership said they cant do anything for me after ecu reflash
Racerkid
May 29, 2012 06:16 PM
saab92x
Mar 16, 2009 03:16 AM
06scooby
Oct 15, 2006 10:11 AM
rash
May 17, 2003 12:32 PM
