5th gear noise?
Old Dec 6, 2004 | 01:40 PM
BlingBlingBlue's Avatar
My '02 wagon has always made a slight whine when cruising in fifth. It's not so much a solid cricket noise as it is a high pitched turbine whine. I'm pretty sure my noise is from the turbo.
If I were you, I'd make a mental note of the noise and not worry about it at all unless it changes.
Old Dec 6, 2004 | 01:55 PM
meilers's Avatar
My 02 WRX whines in 3rd, 4rth and 5th, always at about 2700 RPM to 3000 RPM. It is a continuous, constant whine, not a squeak or a chirp. My guess is that it is the turbo spinning up but dumping boost through the wastegate (boost gauge shows vacuum at that RPM unless you are at nearly full throttle).
STi-owns-evo
Sep 2, 2009 09:04 PM
knele21
Dec 5, 2005 07:24 PM
dynamicprojeKtz
Nov 6, 2005 08:01 PM
STi4life
Mar 1, 2004 11:09 AM
soundwave
Feb 13, 2004 11:39 PM
