Why do wrx's burn oil so fast.!?
Old Nov 19, 2012 | 10:09 AM
rexman 201's Avatar
So there's my question basically.. Why do wrx's burn threw oil so fast ? I just got my 07 an I absolutely love it except the fact I have changed my oil 2 within 5, 000miles. Now I was told that your suppose to change the oil ever 3,000 just like any other car. Is that true or should I change it earlier? As of right now I am a little low on oil as we speak. I have had a full synthetic oil change done and my local shop but the didn't tell me the weight of penzoil. What would that weight be so I can ok a little me in until I get my oil changed
Old Nov 19, 2012 | 11:05 AM
Brfatal's Avatar
Technical Know-It-All
Car Info: '02 WRX + '15 WRX
When was your last compression test?
faraco3's Avatar
Car Info: 06 STi 293hp/310tq / 2.5 FLI tune
I have a stage 2 STi and I run Rotella T6 5w-40 and I never burn oil. I change it after approximately 3000 miles. Some oils don't mix well with the boxer engine.
Old Nov 19, 2012 | 12:11 PM
04GG's Avatar
If in doubt, FLAT OUT
I have 119K and don't drip any oil at all. Cars that leak oil have not been properly maintained or may indicate a more serious issue. If you don't have actual DRIPS indicating leaks, you are burning oil and that could mean blow-by or a possible head gasket issue (do a compression check as mentioned above).
5W30 is the recommended weight.
Old Nov 19, 2012 | 12:48 PM
LOL_VTEC's Avatar
Car Info: 2018 Tacoma TRD PRO
because racecar
Old Nov 19, 2012 | 02:31 PM
SDTONORCALWRX's Avatar
Car Info: 09 WRX E85 tuned
Originally Posted by LOL VTEC
because racecar
I second that!!!
Old Nov 19, 2012 | 02:36 PM
02RS25's Avatar
or possible leaking valve stem seals, which is what i have. smoke at startup or under load if any? smell? color?
because racecar
i third that only cuz the harness bar i bought already had "BECAUSE A RACECAR" written on it. LOL
Old Nov 20, 2012 | 10:19 AM
rexman 201's Avatar
I never checked my compression... I just bought the Rex a month ago. I am using pennzoil full synthetic 5w30. I just have always herd that the wrx's have always burned three oil fast
Old Nov 20, 2012 | 10:47 AM
markyboi's Avatar
Car Info: 2011 swp wrx 5dr
mine doesn't burn any oil. I do all my oil changes and have not noticed a decrease in oil amount.
Old Nov 20, 2012 | 11:14 AM
04GG's Avatar
You heard from the wrong people.
Old Nov 20, 2012 | 11:24 AM
Brfatal's Avatar
Between 3 WRXs over 10 years, built and dying motors aside, I've never burned more than half a quart.
huck
Aug 23, 2017 02:18 PM
imprezav8
13
Dec 9, 2004 05:49 PM
voyager2000
Aug 22, 2004 04:55 AM
The Finn
May 1, 2003 11:18 AM
