top speed in 02 wrx
Old Jul 5, 2004 | 03:03 PM
Wingless Wonder's Avatar
Origami posted by pingpong1000
how fast can wrx 02 go in 1st, 2nd. 3rd, 4 th and 5th
I got 2nd gear to 65 mph at 7000 rpms. I have not red line 3rd, 4th and 5th.
See page 7-11 and 7-12 in your 2002 Owner's Manual. That is the factory recommendation for maximum safely allowable speed in each gear.
1st gear = 35 mph
2nd gear = 61 mph
3rd gear = 87 mph
(Owner's Manual does not list maximum speeds of higher gears)
You will not be able to achieve redline in 5th gear in an unmodified WRX. 5th gear is for highway cruise economy and not geared correctly to achieve top speed.
Old Jul 6, 2004 | 01:59 PM
nachomc's Avatar
I've never run 4th to redline but it does go well over 100mph I know that
I've heard top speeds for the WRX in the 140 range. 4th should take you somewhere between 110 and 120.
Old Jul 6, 2004 | 08:38 PM
gdogg's Avatar
Car Info: 1973 Huevo Ranchero
speed safe on a safe venue with the right tools-
in my wrx wagon i've never exceeded 118 mph. i was too
nervous to exceed that because of the wonderful stock tires
that said- the wrx should reach around 140 unless you have an automatic which(if i'm not mistaken) which is limited to 108 or 110
Old Jul 7, 2004 | 06:50 AM
esracer's Avatar
Car Info: 2002 Honda S2000
Auto limited to 108-110 ahh that must stink!!!
Old Jul 9, 2004 | 12:02 AM
awns729's Avatar
Car Info: want a WRX
The WRX will (depending on temp, humidity, elevation, etc. ... i think) get to ~143. Thats for 02-03. The 04-05 are more aerodynamic and may have a higher top speed, only slightly higher though.
Old Jul 9, 2004 | 02:30 AM
RoadSpike's Avatar
*chuckles*
Well not really, having a friend with an 04' myself at about 130'ish mph the front scoop started to howl like nothing else. We were well beyond the top 140mph on the dail when we stopped though.
Mods to that 04' wrx
accessport stage 2
helix up and down pipe, borla hush
Green panel filter
Even with the stock intake silencer in it has a turbo whistle like you wouldn't believe.
Old Jul 9, 2004 | 05:13 AM
se0ul's Avatar
Car Info: 04 wrx, 05 Elise, 14 Impreza, 17 brz coming soon
Ive gone around 135 to 142 range up and down for about 15-20 minutes straight in my 04 trying to get home in time for new years hah..
Old Jul 9, 2004 | 12:32 PM
awns729's Avatar
Originally Posted by RoadSpike
*chuckles*
accessport stage 2
Green panel filter
If it was a stock 04 you almost definitely wouldnt have gotten past 148ish.
Old Jul 9, 2004 | 12:45 PM
Daredevil's Avatar
i've done over 125 in fourth with a grand or so to go
(im modded)
