top speed in 02 wrx
how fast can wrx 02 go in 1st, 2nd. 3rd, 4 th and 5th
I got 2nd gear to 65 mph at 7000 rpms. I have not red line 3rd, 4th and 5th. |
[QUOTE=pingpong1000]how fast can wrx 02 go in 1st, 2nd. 3rd, 4 th and 5th
I got 2nd gear to 65 mph at 7000 rpms. I have not red line 3rd, 4th and 5th.[/QUOTE] What are you waiting for??!!?!? haha |
[quote][size=1][color=gray][i]Origami posted by [b]pingpong1000[/b][/i][/color]
[font=Arial][color=royalblue]how fast can wrx 02 go in 1st, 2nd. 3rd, 4 th and 5th I got 2nd gear to 65 mph at 7000 rpms. I have not red line 3rd, 4th and 5th. [/color][/font][/size][/quote]See page 7-11 and 7-12 in your 2002 Owner's Manual. That is the factory recommendation for maximum [i]safely[/i] allowable speed in each gear. 1st gear = 35 mph 2nd gear = 61 mph 3rd gear = 87 mph (Owner's Manual does not list maximum speeds of higher gears) You will not be able to achieve redline in 5th gear in an unmodified WRX. 5th gear is for highway cruise economy and not geared correctly to achieve top speed. [size=1][color=skyblue]-- 0==[color=blue]WW[/color]==0 "…axles of evil…" - george w. bush[/color][/size] |
thanks for the info. now all I want to know is how fast 4 th gear will take you.
also to people run stock wrx 02 on race tracks. |
I've never run 4th to redline but it does go well over 100mph I know that :o
I've heard top speeds for the WRX in the 140 range. 4th should take you somewhere between 110 and 120. |
ive gone 140 exactly in 5th at like 5,000 or so rpms but then shut it down
4th gear runs out at about 120 MPH... not that I've actually done it ;) I always obey the posted speed limit!
speed safe on a safe venue with the right tools-
in my wrx wagon i've never exceeded 118 mph. i was too nervous to exceed that because of the wonderful stock tires :) that said- the wrx should reach around 140 unless you have an automatic which(if i'm not mistaken) which is limited to 108 or 110 :( [size=1][color=lime]aloha from the summit of Mauna Kea[/color][/size] |
Auto limited to 108-110 ahh that must stink!!! |
I've done just a hair over 120 in fourth. It was fun.
(disclaimer: don't do it, im crazy) |
The WRX will (depending on temp, humidity, elevation, etc. ... i think) get to ~143. Thats for 02-03. The 04-05 are more aerodynamic and may have a higher top speed, only slightly higher though.
[QUOTE=awns729]The WRX will (depending on temp, humidity, elevation, etc. ... i think) get to ~143. Thats for 02-03. The 04-05 are more aerodynamic and may have a higher top speed, only slightly higher though.[/QUOTE]
*chuckles* Well not really, having a friend with an 04' myself at about 130'ish mph the front scoop started to howl like nothing else. We were well beyond the top 140mph on the dail when we stopped though. Mods to that 04' wrx accessport stage 2 helix up and down pipe, borla hush Green panel filter Even with the stock intake silencer in it has a turbo whistle like you wouldn't believe. |
Ive gone around 135 to 142 range up and down for about 15-20 minutes straight in my 04 trying to get home in time for new years hah..
[QUOTE=RoadSpike]*chuckles*
Well not really, having a friend with an 04' myself at about 130'ish mph the front scoop started to howl like nothing else. We were well beyond the top 140mph on the dail when we stopped though. Mods to that 04' wrx accessport stage 2 helix up and down pipe, borla hush Green panel filter Even with the stock intake silencer in it has a turbo whistle like you wouldn't believe.[/QUOTE] If it was a stock 04 you almost definitely wouldnt have gotten past 148ish. |
i've done over 125 in fourth with a grand or so to go
(im modded) |
