Timing Belt 2007 Sti parts details questions
Can anyone give me a detailed list of everything i need to do a timing belt change? buying parts for someone else to do.
are any these duplicates of one another?
the list i have so far is
Timing belt
Belt idler
cogged idler
idler
tensioner
water pump
belt tensioner
cam seal x4
front crank seal x1
oilpump o ring x1
oem coolant
also, are there any performance modifications that can be made while everything is taken apart?
Timing belt
Belt idler
cogged idler
idler
tensioner
water pump
belt tensioner
cam seal x4
front crank seal x1
oilpump o ring x1
oem coolant
you got pretty much everything covered in the list but I have never replaced cam seal x4=left
front crank seal x1, oilpump o ring x1, usually they never leak unless you got a oil leak going on, let me know if you need someone to take care of the job for you we are newly opened SUABRU shop in SANMATEO 308 7th ave hit us up, look us up on yelp Boxer specialist
Campbell23
Oct 19, 2006 09:15 PM
