(Simple) IC Sprayer control help needed
Old Jul 16, 2003 | 12:08 AM
makofoto's Avatar
Car Info: '03 WRX WGN, Stg 1, No Roof Rack!
I've got the new single nozzle STI IC Splitter ... and would like to provide water to the nozzle using the front window washer sprayer line.
Yes, I know that IDEALLY the sprayer should be auto controlled by boost pressure, throttle position, etc ....
I have the I/C Water Spray momentary switch .... which when I push it, I would like it to activate the front sprayer pump while also activiating a valve that would divert the water through to the IC Sprayer Nozzle instead of the Window Washer nozzles. Activiting the window washer sprayer stalk control would give normal operation to the window washer nozzles.
If this is too complicated ... how about using the rear window washer pump (I have a wagon) ... since I don't need the rear window washer here in Southern CA very often. I wouldn't mind using the end **** of the windshield washer stalk ... but would need to de-acitvate the rear wiper blade itself.
If the rear pump is not strong enough ... perhaps another front washer pump would fit in place of the rear pump? Does anyone know if they are interchangable ... fitment wise?
Old Jul 16, 2003 | 08:54 AM
makofoto's Avatar
As I think I said .. yes I know what an optimal system would entail ... just looking for specific help for what I want to do at the moment. Thanks ...
Old Jul 18, 2003 | 12:24 PM
makofoto's Avatar
Finn ... Apparently Subaru doesn't agree with you ... the STI uses a Sprayer ... not a Mist'er.
I did my Super Simple System ... disconnected the rear wiper on my Wgn, attached at 1/4" tube to the rear pump ... to my STI sprayer nozzle ... and now have IC cooling at the tip of my washer stalk control.
I tested the rear pump ... by simply attaching it to the front window sprayers ... and found that it's quite a bit more powerful then the front washer pump ... the spray went over the top of the car.
Since I basically wanted the sprayer to combat heat soak while at a stop light or waiting in line at the drag races ... and for that relatively long drawn out third gear run at the drag races ... I feel my IC sprayer does what I need it to do.
I would have thought that Subaru would have designed a new nozzle for their new STI Single Nozzle system ... that provides more of a 180 degree coverage ... but they haven't. The nozzle covers more like perhaps 140 degrees ... so the two front corners of the IC might not get coverage ...
I wonder if a mist would be that effective when there is no moving air ... while stopped ... especially since you have heat rising through the IC. Subaru and I think that a coarser spray of water might be the ticket ....
Old Jul 19, 2003 | 11:14 AM
makofoto's Avatar
water rolling off the IC takes heat with it ... physically and when it evaporates.
a lot of the mist in the air goes past the IC fins .... but evaporating mist cools the air ... but as you said ... water cools more the air ...
There is a reason why Subaru doesn't use mist'ers ...
Old Jul 19, 2003 | 11:49 PM
makofoto's Avatar
I don't think you need a temperature gauge ... when one is stopped for a couple of minutes ... the IC starts getting HOT ... at least in our typical Southern CA weather. I think it also makes a difference when one just wants to do a fast squirt ... and I like being able to pre cool the IC ... not waiting to be in a fast run ... when the boost would trigger the sprayer.
Some people think that you can't cool the IC below ambient temperature ... but that doesn not take into account the cooling effect of evaporation. I believe the difference would be like a dry thermometer and a thermometer with the bulb wrapped in something water wet ... the evaporating water would cool that thermometer below the dry thermometer ...
Old Jul 28, 2003 | 12:19 PM
blubaru's Avatar
Car Info: '02 WRX wagon
Re: (Simple) IC Sprayer control help needed
Is this splitter from the '04 Sti? And it will fit the '02-'03s? Details please.
djwonder925
Apr 22, 2013 10:09 AM
Spoolin415
Apr 9, 2008 10:20 PM
SpdingTktsInc
Jun 11, 2005 08:07 PM
krillz
Jul 2, 2003 04:37 AM
Astacun1
Jun 28, 2003 03:12 PM
