oil level too high
Old Apr 15, 2003 | 12:08 AM
LMON50's Avatar
Car Info: 2002 WRX Wagon
oil level too high
changed my oil recently and accidentally ended up putting in too much oil (synth). the level is just above the "F." how important is it to remain below this mark. should i remove some or will it potentially cause problems if left alone.
thanks
Old Apr 15, 2003 | 12:22 AM
joltdudeuc's Avatar
Old School
Car Info: '99 RBP GM6
if the engine is cold (not run in 4 hours) and it's *just* above F, i think you're ok.
tip: www.fumoto.com
buy a fumotovalve (non nipple), and you in the future, your oils changes will go Smoother and if something happens like you put in too much, it's super easy to take out a tenth or two of a quart!
-Gagan
Old Apr 15, 2003 | 12:40 AM
4080wrx's Avatar
you should stay within the two marks on the dip stick. anything more than full can cause a leak. (but we are talking like 1/2 of qt or more) when the oil pressure builds in the engine, oil will typically go out the weakest point. which is usually a gasket. the easiest way to remove excess oil would be to just remove the oil filter and drain whats in the filter and what comes out of the filter spout. this is usually only about 1/3 to 1/2 a qt. after start the engine and recheck.
4080
Old Apr 17, 2003 | 10:04 PM
LMON50's Avatar
thanks guys,
did the drain through the filter and the amount released was perfect.
Old Apr 18, 2003 | 02:09 AM
4080wrx's Avatar
no prob jus helping a fellow i clubber
4080
chakming888
Oct 31, 2010 10:20 PM
lovesmysuby04
Aug 19, 2005 09:55 PM
schafer
Oct 21, 2004 10:21 AM
deks
Aug 1, 2004 07:03 PM
EvoEater
Apr 1, 2003 09:18 PM
